I'll try one more time
Old Jun 1, 2009 | 11:02 PM
terravast4's Avatar
Default I'll try one more time
getting ready to do the gt2-3 cam and a texas speed 2.5 (5.3) head swap on the radix as well as the 90mm throttle body. Anyone running 1.8 rockers with this cam?? Should I just get some good 1.7's or would there be some benefits to the 1.8's on the little 5.3? Please respond i am buying soon. Thanks.
Old Jun 1, 2009 | 11:08 PM
silver-mod-o's Avatar
Hunt&Fisherator
I have the Crane Gold 1.7 roller rockers with my GT2-3 cam but they came with the heads I've got... If I were building one, I'd just run stockers with good springs/retainers...
Old Jun 1, 2009 | 11:22 PM
terravast4's Avatar
So the stockers are just fine? no real gains to be had?
Old Jun 1, 2009 | 11:32 PM
Hunt&Fisherator
None to speak of unless you're just looking for every single tiny drop of power... They require guide plates and have to be set up correctly as well where the stockers are torque and go... I'd also drop some good pushrods in there while you've got it apart.
Old Jun 2, 2009 | 12:00 AM
terravast4's Avatar
I already got the pushrods...............just don't want to waste money on things I don't need . Thanks a lot.
Old Jun 2, 2009 | 12:28 AM
trenz68's Avatar
Im also running the same cam and setup. Was told all that needs to be changed is the springs and rods
Old Jun 2, 2009 | 12:40 AM
thunderwagen's Avatar
You will be fine with stock. If the valve guides had been replaced with bronze then I would go with rollers.
thunder550
Oct 8, 2015 04:53 PM
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
therock
Aug 23, 2015 01:37 PM
