Idling issues
Ok thanks to KB racing I finally got my hot pipes and finished my turbo setup went to fire it up and it barely idles and when I put it drives it goes no where is this normal truck isn't tune yet but is this normal
It's a 4.8 with a 216/220 114 lsa 3000 stall walboro fuel pump electric fans my rear 02 were tuned out cause I had no cats on the longtubes tuned by flaco turbo setup is a front mount intercooled 62mm turbo that I added to what I already have
What yr truck and how is the maf set up in the piping? Try to remember that the maf is use to reading without all that piping and intercooler in front of it as well. Bigger injectors or stock?
The maf is right infront of the throttle body I'm picking up 42lb injectors today and my truck is an 03 oh I forgot to mention that I only got one 02 plugged in that's the one on the drivers side front I got to stretch the passenger front connector so that's not plugged in don't know if that would make the difference the rear ones were tuned out
This is probably your problem, more than likely your tune is set up to run off the sensor you don't have in place. Extend the harness and hook the sensor up and see how it runs.
A few months back Actually I kept the cam in it too wanted to stand out here in Katy Tx Feels pretty cool people are breaking there necks when my blow off valve goes off or when they hear the turbo spool :-)
smokeshow
Aug 23, 2015 08:23 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
GreyChevy
Jul 7, 2015 08:57 PM
