IAT vs timing safe point
Old Jul 14, 2018 | 02:52 PM
trxmxzx's Avatar
13 Second Truck Club
Originally Posted by terravast4
super chiller
my buddy was trying to talk me into that- I don’t want to mess with my a/c it works better than any of my current vehicles (and has the most miles)
thought maybe a hillbilly way for the summer time to use the heater core and run ac, then blend the air.... but it was a thought
i think it it will be just the water/meth solution or turbo setup
Old Jul 14, 2018 | 02:56 PM
trxmxzx's Avatar
Oops I was thinking of killer chiller
my intakes drop pretty quickly after a pull- maybe 3 minutes it’s around 125 degrees
Old Jul 14, 2018 | 04:11 PM
trxmxzx's Avatar
I used to run a mp112 @ 12# and nelson also tuned it. when I added meth I noticed a big difference on the top end it felt like it just pulled harder and harder. I think the meth made just enough difference it didn't pull timing
what size nozzle you use? They start at 60 ml/min to 625 ml/min (snow performance) I’m looking at there stage 2 I want it to progressively come on depending on boost level.
Old Jul 21, 2018 | 10:46 PM
trxmxzx's Avatar
So looking through this last log - I drop 52 degrees in 1 min and 2 seconds -
Time- temp degree
18.40.46.2- 174degrees
18.41.10.3 - 133 degrees
18.41.44.7- 122 degrees
18.41.52.6- 120 degrees
18.42.05.1- 118 degrees
outsidetemp was 76
Old Jul 22, 2018 | 07:04 AM
03sierraslt's Avatar
How close to ambient will your temps get at steady state cruise on the highway?
Old Jul 22, 2018 | 10:29 AM
trxmxzx's Avatar
if its 70 or 95 at 2100 rpms cruising on eway doing 79 mph it’s between 120-124 degrees
Old Jul 22, 2018 | 11:42 AM
terravast4's Avatar
thats right about where I was with my mp112
Old Jul 22, 2018 | 12:11 PM
So IAT stays the same even if ambient is 70 or 95?
Old Jul 22, 2018 | 12:14 PM
terravast4's Avatar
Mine did. You spin that little blower that much its gonna generate some heat
Old Jul 22, 2018 | 12:16 PM
terravast4's Avatar
You are also sucking in that hot engine air too
