iat placement ?
Old Jun 22, 2012 | 03:18 PM
  #31
foose04's Avatar
I have maf fail setup, i'll double check those codes when I get home. Thanks bud!
Old Jun 24, 2012 | 10:37 PM
  #32
slow67's Avatar
Gingervitis Addict
Yeah you can turn off the SES light for the codes, but make sure it sets one of those 3 codes.
Old Jun 25, 2012 | 01:19 PM
  #33
TURBHOE's Avatar
what map sensor are you running?
Old Jun 25, 2012 | 03:04 PM
  #34
nonnieselman's Avatar
Originally Posted by TURBHOE
I just went to napa and bought one for a cyclone and the pigtail to go with. Napa had it all in stock.
It's threaded copper looking with an element and little plastic cage around the element.
Thats pretty neat.. you have a part number or anything?
Old Jun 25, 2012 | 05:14 PM
  #35
Beatdown Z's Avatar
Laid Back
I used the MSD sensor.
Old Jun 25, 2012 | 06:16 PM
  #36
foose04's Avatar
I want to say it's the Chevy Cobalt ss 2 bar sensor.
Old Jun 25, 2012 | 07:18 PM
  #37
TURBHOE's Avatar
ok so you are using a 2bar os? your mac should have been set to fail from the get go. just set the codes to "no light" and mac fail to 0. thats all you have to do with a 2bar os via hpt.
Old Jun 25, 2012 | 07:32 PM
  #38
blue0453's Avatar
thanks bro.. back on topic
Old Jun 25, 2012 | 08:04 PM
  #39
foose04's Avatar
Correct, i'm on the 2bar OS with the maf failed, however you just can't remove it with that alone & be fine as i've tried. I think it needs the AIT signal, or at least disable it as there are few table that us AIT to determine mapping. I'll be home soon and update this thread what I did when I get that AIT sensor wired up.
Old Jun 26, 2012 | 01:46 PM
  #40
slow67's Avatar
Gingervitis Addict
yes, you should use your IAT sensor, its used in fueling calculations for speed density. Just get the 5 wire to 3 wire MAF harness so you can split out and use an external threaded IAT sensor. Then you can completely ditch the MAF (although I would keep it, and let it stay failed so you can track airflow changes on back to back runs for testing, like your intake manifold testing ).
Racetronix - MAF Adapter 3-Wire + IAT > 5-Wire GT
GMCtrk
Jan 27, 2016 06:47 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
JordanH
Oct 3, 2015 03:59 PM
dantheman1540
Sep 18, 2015 03:03 AM
TAPyvehc93
Sep 17, 2015 10:10 AM
