IAT moved ???
Old Oct 26, 2006 | 02:09 PM
NXRICKY's Avatar
Former Vendor
Default IAT moved ???
Ok wnet through the search, and still need a little help. Moving the iat out of the MAF. There was a thread that told you the color codes and had a simple drawing helping explain this process.
any ideas?
Ricky
Old Oct 26, 2006 | 02:11 PM
Whippled 496's Avatar
If you have the 5 wire MAF, its the TAN and BLACK wires next to each other on the end of the connector.
Old Oct 26, 2006 | 02:15 PM
BlackGMC's Avatar
Resident Retard
Sorry to get off topic but what is the benefit of doing this?
Old Oct 26, 2006 | 02:16 PM
NXRICKY's Avatar
Former Vendor
yep 5 wires. Ok will it matter which wire goes where on the new sensor.
Thanks
Ricky
Old Oct 26, 2006 | 02:21 PM
NXRICKY's Avatar
Former Vendor
I am just about to hook up my water/meth, and MAF sensor wires do not like the ethanol. It can eat away at the wires. So I am moving that sensor to the intake and spray the meth after the maf.
Ricky
Old Oct 26, 2006 | 02:23 PM
BlackGMC's Avatar
Resident Retard
Ricky
Thanks so it is really only for FI with Meth? Sorry to jack your thread.
Old Oct 26, 2006 | 02:25 PM
NXRICKY's Avatar
Former Vendor
yeppers and no problem.
Look like a runner is going to be the easiest area to get ahold of. Any one recommend and epoxy to hole this in.
Black is ground, Tan is signal.
Old Oct 26, 2006 | 02:26 PM
NXRICKY's Avatar
Former Vendor
Two pins in the sensor does it matter which pin I plug to which wire.?
Old Oct 26, 2006 | 02:30 PM
What sensor are you using? Is it a new IAT sensor? It should be marked which is ground, or have pigtails coming off of it in which one should be black. I would imagine it DOES matter how its hooked up, but without seeing which sensor your using i cant be sure.
