I think I am screwed!! (Radix Install)
Old Apr 15, 2006 | 02:24 PM
Default I think I am screwed!! (Radix Install)
I found out how to get the fuel pump out finally. Now, the fuel pump Magnason sent me isn't the same as the one in the directions. Mine came with 2 electrical connectors and a brass fitting that I have no clue as to where they go.
#2. I didn't receive a coolant vent tube from the guy I bought it from. Is there anyway I can modify the stock one and make it work?
Magnason really needs to work on their instructions on how to install the new fuel pump 'cause the directions I got are useless.
Somebody please help!!!
Old Apr 15, 2006 | 02:36 PM
BlownChevy's Avatar
blownerator
25 Year Member
So let me get this straight...you bought a used kit, and bought a fuel pump from Magnuson? Now you are mad because the instructions do not state how to install the pump? Where did you get the instructions? Take some pics and post them up so that we (I) can see what you have going on.
The instructions for the Hummer H2 Fuel pump should help you if you are using an older set of instructions. I notice that Magnuson web site is down in a few places, I hope this helps.
http://www.magnacharger.com/pdf/manual-HummerH2.pdf
FWIW Magnsuon has the BEST install instructions in the industry, you might want to double check that you have the right pump.
Old Apr 15, 2006 | 02:50 PM
Mr. Sandog's Avatar
Yo man - trying to respond to your PM but your inbox is full....
Old Apr 15, 2006 | 02:51 PM
That is the exact fuel pump I got. Thank you, Thank you, Thank you!!!
I am using the 2003/2006 instructions I downloaded off Magnason's website. The instructions you just gave aren't the same as the ones I have.
Other than the fuel pump I haven't had any other promblems w/ the instructions.
Do you think I can modify the coolant vent tube to make it work.
Old Apr 15, 2006 | 03:10 PM
BLOWN 364's Avatar
I dont think you will be able to make it work.
Thats why they supply a new one with the outlet on the passenger head because the blower needs the clearance where the stock comes out on the drivers side
Old Apr 15, 2006 | 03:51 PM
BlownChevy's Avatar
blownerator
25 Year Member
Thats a BIG negative....you will need the correct coolant vent pipe.
Old Apr 15, 2006 | 03:52 PM
BlownChevy's Avatar
blownerator
25 Year Member
empty
Old Apr 15, 2006 | 05:46 PM
any idea on what one would cost if I have to buy one?
Old Apr 16, 2006 | 12:16 AM
Bowtie70SS's Avatar
I wouldn't think over $20-$30...They aren't too unreasonable on their parts.
Dave
smokeshow
Aug 23, 2015 08:23 PM
Shtbox
Aug 2, 2015 10:52 PM
walledition
Jul 29, 2015 08:54 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
