i need schooled on getting blown LOL
Old Aug 23, 2007 | 09:26 AM
beastmode's Avatar
Import Moderator
Default i need schooled on getting blown LOL
i can pick this blower up for $300, its an Eaton blower off of a Lighting wit about 35k miles on it and there is nothing wrong wit it. my question is with a custom sheet metal intake will this thing work on my truck and is it worth it? it sounded like an awesome deal and i figured i could get it ported to. im just basically trying to figure out how much work & money ill have into this or if its just gettin in over my head
Thank you for any help
Old Aug 23, 2007 | 09:32 AM
TouchOfEvil04's Avatar
If it will fit then go for it. Get it ported and you almost have a radix blower minus the intercooler setup.
By this i mean it will flow almost as much air as the normal radix.
Not it will magically become one.
Just wanted to clear that up after reading what i posted lol.
Old Aug 23, 2007 | 09:36 AM
beastmode's Avatar
Import Moderator
ya i kinda figured you didnt mean that lol
ya thats what im worried about is it not fitting, basically i figured i could have the blower for $300, the intake for probably $1000~, then i assume id need some injectors (wat size??), and i would like to do the intercooler to if i can pick one up for cheap on ebay
im just trying to see if there is anyone running a L blower basically
Old Aug 23, 2007 | 09:44 AM
FastCrewCab4x4's Avatar
You May want to get Brian in on this. He should know if it's even a possibility.
It looks taller, you may be needing a hoodscoop.
Old Aug 23, 2007 | 09:46 AM
Quik's Avatar
5 year bitches!
im sure it can be done but youll have alot into the intake and elbow. thats some fab work, Jay & TJ could get it done but then youll need brackets and etc for the belts and pulleys
Old Aug 23, 2007 | 09:51 AM
TXsilverado's Avatar
i heard the eaton blowers on lightnings are inefficient as all get out...thats why alot of them swap over to KB blowers.
Old Aug 23, 2007 | 09:54 AM
tiffo60's Avatar
there very efficient up to 8lbs of boost which is what there designed for, but when you spin them harder as all lightning owners do in the 15lbs+ range they put out alot of heat, but i wouldnt run one with out an intercooler
Old Aug 23, 2007 | 09:56 AM
beastmode's Avatar
Import Moderator
ya i plan to run a cowl hood by then hopefully that would be enough room
ya thats what i was thinking just have him fab up all the stuff for it.. just wasnt sure how much it would all be and how much works involved
well hopefully if i were to get it ported it wouldnt be that bad
i figured all in all i could have the whole setup done for about $2500 or so not including you tuning it up Quik... where as if i buy like a radix or something ive seen em going used for ****** $5000
Old Aug 23, 2007 | 09:58 AM
beastmode's Avatar
Import Moderator
ya thats all im lookin for is like 8lbs or so, i figure that should be a nice little HP gain for like $2500. would i have to have the intercooler built into the manifold, not sure if thats how they work?
thanks alot guys this is a big help
ive seen them new for way under 5,000 new. talk to vendors directly. they cant advertise prices below a certain point because of contracts.
