Huron speed downpipe issues?
Old Aug 24, 2019 | 06:34 PM
Resolute_welding's Avatar
Hey guys, just an update. New downpipe fits great! Truck runs pretty good! Been trying to figure out why my EBC isn't working but I THINK I got it figured out. The turbo is LOUD.
Old Sep 8, 2019 | 09:46 AM
Fabricator909's Avatar
Finally about got mine ready to goto the dyno as well. My down pipe needs some more bend at the v flange that connects to the muffler side. Its pointing down about a couple degrees and won't allow the extension to be bolted in place turned the correct way. I'll take a jack and push up on the bend , then do some heat shrinking with the torch to get the bend to come up.
Also the oil outlet on the huron speed turbo is a complete pain in the ***. The drain hose needs bolted to the outlet manifold and clocked correctly AND you have to ditch one of the compressor clamping bolts in order for it to fit.
No clearance here.
Intercooler mounting bracket is too short???
I fabbed the coolant reservoir tank to go under the fender brace.i also deleted the Y at the water pump and converted it to a T at the reservoir tank.
Old Apr 26, 2020 | 11:46 PM
ertoys's Avatar
Ertoys
Looks really nice!
Im still waiting on my Huron kit from the GP, I sure hope they've figured these issues out by now.
Old Apr 27, 2020 | 05:30 AM
infam0us1's Avatar
Originally Posted by ertoys
Looks really nice!
Me toooo! I am ready to start having problems of my own!!!LoL
Old Jan 1, 2021 | 10:21 PM
ertoys's Avatar
Ertoys
FINALLY starting to get this installed.
my 90 coming off turbo is smashing (deformed) up against the thermostat housing. Anyone have a remedy?
Old Jan 2, 2021 | 05:22 AM
Superman09's Avatar
Truck Sponsor
depending which turbo you are running, this outlet may be higher or lower than another. If you are too low and touching the t stat housing on the coupler off the turbo, you can simply trim the coupler a bit on the turbo side to slide it up higher on the turbo and it will give you more room here. Anything you need always feel free to reach out direct, always happy to assist! Jon@huronspeed.com
Old Jan 4, 2021 | 12:48 PM
zz454Chevelle67's Avatar
My downpipe was pure hell to get installed but but once it was on it has plenty of clearance, my only real issue was a leaking fitting from the turbo oil feed line at the turbo. Leaked onto the turbo blanket and smoked like hell. Scared me good when I smelled burning oil and saw all that smoke coming out from under the hood. New feed line and turbo blanket and its good except transmission it aint very happy right now.
Old Sep 15, 2021 | 12:43 PM
Sloop's Avatar
The new design looks really good, looking forward to getting the T6 setup.
slowlsx
Jan 5, 2013 08:43 PM
LsxCody
Mar 13, 2012 12:37 AM
054.8 silverado
18
Jan 26, 2008 09:17 PM
Z1500
Jan 2, 2005 11:18 PM
