HP/TQ expectations on a Whipple install on a 5.3?
Old Sep 30, 2019 | 05:02 PM
smokinlmm's Avatar
I'm running stock converter and trans in mine and it's my DD, does fine, holds power and stills drives nice from stop light to stop light. You had better budget a Detroit Truetrac bc the g80 dosen't like PD blower torque.... Lol....
Old Sep 30, 2019 | 05:18 PM
RMC_SS_LDO's Avatar
Originally Posted by smokinlmm
...the g80 dosen't like PD blower torque.... Lol....
Way to kill my hopes and dreams LOL!
Have the 3.42 G80 but not lifted and on very close to stock tires. On the plus side, breaking stuff means stronger replacements...
Allen
Old Sep 30, 2019 | 08:03 PM
Talstar's Avatar
My 5.3(extcab 4wd) with similar setup made 485whp with a Vortech blower at 9lbs. Only think different besides type of blower is we installed a small air-to-air intercooler.
Old Sep 30, 2019 | 08:22 PM
ZO6Ted's Avatar
On the G80 subject this is second hand info so you know how that is but I understand what kills them so quickly is uneven traction such as one wheel off of pavement or doughnuts and such. Parish 8 I believe was his name (the father of turbo 4wd) ran some badass #'s on a G80. I thought it was 10's. Maybe make the time bomb last a little longer if you avoid the above stupidities lol.
Old Sep 30, 2019 | 09:53 PM
MikeGyver's Avatar
Mine hasn't broke yet. I guess it will tomorrow now that I posted this.
Old Sep 30, 2019 | 11:16 PM
arthursc2's Avatar
The bigger ones are better than the 8.5" ones
Old Oct 1, 2019 | 05:37 AM
smokinlmm's Avatar
Mines was an 8.6, I cracked carrier housing in 2 places. I do a lot of burn outs and power sliding so I wasn't shocked when I whacked it. I'd still budget for it, it's a ticking bomb that when it goes can really f some stuff up badly.
Old Oct 1, 2019 | 11:04 AM
Talstar's Avatar
I went ahead and installed a Trutrac in mine since I was changing gears. The axles needed replacement also, 250,000 miles will do that
Old May 6, 2021 | 09:50 PM
ertoys's Avatar
Ertoys
Originally Posted by RMC_SS_LDO
My 2010 Silverado ext cab (4wd) is going under the knife for a 2.3 Whipple and other supporting upgrades- bouncing off the walls looking forward to it!
The question is what are realistic numbers that I should expect? For reference, the truck is currently bone-stock (LC9 engine) and very low miles but doing the following:
Whipple Supercharger W140AX (2.3L)
6-rib pulley 3.5"
Stainless Works Stainless long tube headers (3.00" slip fit collectors) w/high flow metal matrix catalytic converters
Stainless Works catalytic converter-back exhaust system (2.50" inner diameter) Dual under bumper exit
MSD Ignition spark plug wires
DEI Spark plug wire Protect-A-Boot sleeves
ARP Cylinder head bolt kit-chromoly, Pro Series, 12-point head style
Dual valve spring kit maximum lift: .660
Comp Cams Hi-Tech chromoly pushrods
CNC port/polish heads and 2" intake valves
LS7 hydraulic valve lifters
Custom designed billet-core camshaft - 3-bolt conversion
LS2 timing chain damper
Katech Performance Parts C5R/C6R timing chain
Melling High Volume Oil Pump
LSx 160 thermostat
Walbro 450lph (E85 Compatible) Fuel Pump
Full dyno tune
Interested in what kind of numbers others with similar builds have seen...
Thanks in advance!
Allen
So, what did your rig end up running?
i’m getting ready to do my 07 Silverado 5.3 with 2.3 Whipple 3.175 pulley, meth injection, FIC 1000 injectors, innovators West eight rib set up with 10% overdrive crank pulley, 1 7/8” long tubes and BTR stage 3 PDS blower cam and all supporting mods....4L80 conversion soon to follow laughing out loud.
Old May 7, 2021 | 08:30 AM
RMC_SS_LDO's Avatar
I wound up a shade over 500/500 at the wheels, which was on-point for what I was looking for. Didn't build it as a racer- It's a daily driver that has some towing duty. The thing is a blast to drive now and stayed with the stock stall converter for towing. It's is what GM should have offered OEM!
With your setup, I'd expect more but you didn't mention if your truck is 4wd. Mine is and mention it for 2 reasons- the extra parasitic drivetrain power loss hides the gains and it would be REALLY challenging to drive in the rain without 4-auto!
Allen
ss4chad
May 17, 2016 04:23 PM
907infamous
Aug 1, 2011 12:50 PM
blander66
Oct 25, 2008 10:31 AM
UNDERR8D
Jan 27, 2006 05:55 PM
YukonSS
Nov 2, 2003 11:27 PM
