Hows this cam for my tvs1900????
Old May 6, 2011 | 01:06 PM
01 BERGER CAMARO SS's Avatar
Default Hows this cam for my tvs1900????
Sup guys, i got offered this cam for my set up but wanted to see what you guys thought about it. My truck is not a daily driver nor does it see track time. What are your thoughts?
Cam Specs
Intake duration @ .050 lift 228
Intake duration @ .050 lift 234
Intake lift is .571 with 1.8 rockers .605
Exhaust lift is .576 with 1.8 rockers .610
113 LSA
Motor
Forged 370------(-16cc probs & eagle rods and ARP everything
Ported 243 Heads
Roush TVS1900
Snow Performance Meth Kit
CONVERTER AND GEARS WILL COME AFTER CAM HAS BEEN BOUGHT
Old May 6, 2011 | 03:47 PM
PediDr2's Avatar
Duration is prolly ok for a 370, maybe more LSA?
Old May 6, 2011 | 05:52 PM
TIM Z's Avatar
11 sec. Truck Mod
Leftcoast Joe told me 115 LSA is most optimal for a blower setup. Not sure how the cam you are looking at will work.
My cam isnt optimal for my setup but it still works great and makes 520+ to the wheels.
Old May 6, 2011 | 06:51 PM
wkdivr's Avatar
Take a look at this, or the other Maggie cam these guys have. You probably want to stay in the 115-116, or slightly higher LSA range.
http://leperformance.com/leplsstgiiblowercamshaft.aspx
Old May 6, 2011 | 06:56 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Do you want more power down low, or way up high in the rpm? Grunt/torque cam specs will be way different than max hp/racing cam. What are you trying to get out of it(goals)?
Old May 7, 2011 | 12:59 PM
EVILGMC's Avatar
114 is the lowest LSA i would go
Old May 7, 2011 | 07:33 PM
old motorhead's Avatar
Bigger than I'd want to fool with. Probably won't give you any more power vs a smaller cam with wider LSA. Just move the power band around a bit. I'm pretty happy with my 215/227 .603/.613 116LSA. It's on a forged 6.0L with ported LS2 heads. Near perfect manners and pulls hard to 6000rpm (shift point).
OHsixLS3
Dec 27, 2016 09:30 AM
rednekferlife101
32
Jan 8, 2016 10:42 PM
tim wellington
Jul 31, 2015 03:28 PM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
