How well do yall think this check valve will work
Old Oct 20, 2012 | 05:41 PM
BlackGMC's Avatar
Resident Retard
Default How well do yall think this check valve will work
I currently have a catch can inline with my pcv setup and it has 3/8 fittings on it. I was wanting to put this valve inline with it to make a nice clean look. It is made for air compressors so i figure it will hold up to 15psi.
Viair Corporation - - VIAIR Check Valves - Overview - SummitRacing.com
Old Oct 20, 2012 | 09:37 PM
Low_S-10's Avatar
They can hold over 200 psi, on my old s10 when i had viair compressor i had one of them start leak air for the air tank back into the compressor. It should work but i dont know how much pressure it takes to open the valve. I have a old compressor head with the leader hose and check valve on it if you want it to experiment with it. You can have it for free, it should still be good the compressor it came off of locked up.
Old Oct 23, 2012 | 10:03 AM
carbongmc's Avatar
I ordered one from McMaster Carr that is similar. 1 psi opening pressure, good to 200 psi total with 1/4npt female on each end. This should work fine, I would imagine.
Old Oct 23, 2012 | 11:16 AM
nonnieselman's Avatar
Yea.. your looking for one that has a really low cracking pressure..
That one might be a bit higher for the air compressor stuff.
Old Oct 23, 2012 | 11:17 AM
Ive got one of these.. just gotta get around to putting it on.
http://www.smcusa.com/top-navigation...els.aspx/22170
also put one on my airbags incase my compressor dies i can just swap hoses for my manual valvestem.
Old Oct 23, 2012 | 12:11 PM
Ferocity02's Avatar
Here's some more options from my thread on tech: https://ls1tech.com/forums/forced-in...ck-valves.html
I think I'm going to try the GM one, it has 3/8" hose barb ends.
Old Oct 23, 2012 | 12:30 PM
Silverado256's Avatar
I've been using this check valve for about a year now works great. Before i used a catch can it had oil in it and didn't affect it what so ever. .5 psi cranking pressure.
3/8" PP Standard Check Valves | U.S. Plastic Corp.
The_W
Oct 28, 2015 09:00 PM
TAPyvehc93
Aug 21, 2015 05:19 AM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
