how much Vacuum does my truck have?
Old Apr 7, 2009 | 07:28 PM
05crew's Avatar
Default how much Vacuum does my truck have?
i am having BOV trouble!!!! i did not have the turbo hooked up at the time i was putting on the tial 50mm, i taped in my brake booster and ran a vac line to the BOV. fired the truck up and i would not open when you rev it up. so i was told to cut the spring. it was a 9psi spring). so i cut a little at a time and keep trying it till it would open up. now i think i cut off to much. because when it is in drive at a stop light i hear a VAC leak. and its the BOV doing it. so i going to get a new spring and going to try a 7psi one.
anyone have this same **** happen?
Old Apr 7, 2009 | 07:31 PM
nonnieselman's Avatar
My LQ4 pulls 9.5psi Vacuum. 19inHg? i think
Try to get a washer or something to Shim the spring now..
Old Apr 7, 2009 | 07:32 PM
SpoolinChevy's Avatar
I have a 50mm BOV also, in neutral, it only goes off above 5k rpms. As long as it operates fine while driving then it should be fine, I would not cut the spring without testing it under load.
Old Apr 7, 2009 | 07:37 PM
2ktransam's Avatar
I run a 7lb spring in my Tial. I tried 11 and 9 first but it wasn't very responsive with the cam so I ended up using the 7lb spring.
Old Apr 7, 2009 | 07:43 PM
turbomax's Avatar
i had the same problem when i installed my BOV to the brake booster line it wouldnt open so i ran the line to my intake manifold problem solved run your vac line to your intake manifold.
Old Apr 7, 2009 | 08:05 PM
05crew's Avatar
so you still get a little comp surge with the 7psi spring. i like a little surge...LOL
Old Apr 7, 2009 | 09:29 PM
ILuvJDM's Avatar
don't ever cut the spring... and like tanner said don't do anything without testing it under load on the street. you shouldn't be "blowing off" in neutral anyways unless you're auditioning for fast and the furious 5
Old Apr 7, 2009 | 09:30 PM
ILuvJDM's Avatar
if you want, get a vacuum manifold from Golden Eagle or an equivalent and run that to your BB vacuum line and then every accessory will tie into that. It's alot cleaner and easier than having a bunch of plastic T's throughout your engine bay.
Old Apr 8, 2009 | 05:35 AM
05crew's Avatar
2ktransam..still get a little comp surge with the 7psi spring.
Old Apr 8, 2009 | 07:49 AM
2ktransam's Avatar
Only a little when I'm at part throttle and back out of it with really low boost. I don't get any surge letting off from WOT.
