how much Vacuum does my truck have?
Old Apr 10, 2009 | 10:19 AM
  #21
Mort's Avatar
My engine runs ~ 8.9 lbs of vacuum at idle and a little over ~12 lbs on hard deceleration. If you run a 9 lb spring or less you will likely be sucking in dirty unfiltered air at idle. If you are at sea level, more or less, you should probably run an 11 lb spring so your BOV only opens on quick deceleration to reduce compressor surge and reduce the sudden increase in boost pressure on the throttle body plate and compressor wheel.
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
mrgrim
Jul 8, 2015 08:12 AM
Hmguyton
Jul 7, 2015 03:29 PM
