How much timing should I have....
ran the truck with a scanner and showed 14 degrees at wot, o kr
1-2 kr on light throttle on incline, lot's of timing when just cruising at steady speeds.
Is 14 wot ok or should it be higher. 80 degrees outside and 115 iat's.
stock 3.4 pulley and stock radix tune.
thanx
thanx
thanx
thanx
The stock Radix calibration is set up for 16* of timing out of the box (safe). Seeing 14* at WOT means that the IAT correction table was more than likely pulling the 2* if the IATs were 130ish at WOT. Sounds about normal to me, the PCM is doing its job.
that makes sense, do the iat's seem alittle high for that ambient temp?
80 and 130 degrees
Blown, did you received the superchips and escalade fuel pump i returned to you,
thanx for your help on that too.
80 and 130 degrees
80 and 130 degrees
80 and 130 degrees
got it, thanks..
130* under boost at WOT sounds normal to me.......
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
therock
Aug 23, 2015 01:37 PM
