How much psi would i get...??
Old Jan 24, 2010 | 01:31 AM
  #21
Blown06's Avatar
8 Second Truck Club
Not to burst your bubble but a cog drive will destroy your D1. The transmissions in the D series blowers don't cooperate with cog drives. You should not have any issues with belt slip and a 4.1 pulley.
Old Jan 24, 2010 | 09:29 AM
  #22
lablackbeast's Avatar
doesn't know what quit means
but i wanted to run a smaller pulley.. what is the diff between the cog and the 8 rib..?
Old Jan 24, 2010 | 10:49 AM
  #23
Rick_Vor's Avatar
Originally Posted by lablackbeast
what pulley will get me there without belt slipping...??
A 3.70" should get you to around 15lbs.
Originally Posted by siktruk
i vote you buy the cog set up
No need, expensive to convert to and they are rough on the Procharger bearings and gears (unless you run one of those slipper clutches).
LLB, Every motor/combination is a little different. Get it running with the 4.10" and see where your at on boost. The 10.5-11lbs is going to seem awesome and then you'll have a chance to get everything dailed in (fuel, tune, transmission, etc) before you step up the boost.
Rick
Old Jan 24, 2010 | 11:40 AM
  #24
Rick
what about if i do the 3.70 and bigger crank pulley...?? how much psi can i get WITHOUT over spinning the pro..??
Old Jan 24, 2010 | 04:28 PM
  #25
sureshot's Avatar
It's not that you'll be over spinning the D1, they just don't like cog setups. You'll be just fine with a 6 or 8 rib setup. As far as psi, like Rick Vor said, start with the 4.1 and then step up from there.
Old Jan 24, 2010 | 09:58 PM
  #26
Rick_Vor's Avatar
You will need to switch out that under-drive pulley your running for a stock OEM harmonic balance/pulley. You won't need to worry about over-spinning a D-1SC. It will take some pretty serious RPM and boost to redline it.
Rick
Old Jan 24, 2010 | 11:11 PM
  #27
Rick
so it wont overspin if i put a bigger crank pulley...??
Old Jan 24, 2010 | 11:43 PM
  #28
Blown06's Avatar
8 Second Truck Club
Dude, you can calculate blower speed. I showed you how here: https://ls1tech.com/forums/forced-in...sc-346-ci.html
...and again, you shouldn't be overly concerned with boost numbers. As I have told you and as others have stated on this thread, start small (bigger pulley) and work your way up. There is no magic pulley combo that we can tell you that will make 15 psi. So your gonna just have to work into it.
Old Jan 25, 2010 | 12:28 AM
  #29
ok man thanks i guess i ma try that
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
old motorhead
Sep 29, 2015 08:22 PM
