How much psi would i get...??
Old Jan 15, 2010 | 10:45 AM
lablackbeast's Avatar
doesn't know what quit means
Default How much psi would i get...??
how much compression can i run with a 11 to 2 conpression...?? and how much psi will it get with a 4.1 pulley on a D1..?? its a 370
Old Jan 15, 2010 | 10:55 AM
Mangled03gmc's Avatar
Baltimore Whore
11-1comp and 10 or so psi isn't going to get along. You will need to have meth injection, dump some timing in your tune if you want it to last.. How about trying a bigger pulley or a boost of around 5-6 psi
Old Jan 15, 2010 | 03:10 PM
silver-mod-o's Avatar
Hunt&Fisherator
different heads maybe to lower compression??? that combo will be responsive as all get out but will nto likely last long.
Old Jan 15, 2010 | 03:15 PM
SLOXCAB's Avatar
I have some stock 241s if you need them
Old Jan 15, 2010 | 03:16 PM
00ChevyScott's Avatar
Wearin' da big hat
Old Jan 15, 2010 | 03:47 PM
SLOXCAB's Avatar
Lol..
Old Jan 16, 2010 | 11:05 PM
Rick_Vor's Avatar
The 4.10 is good for about 11.5-12lbs on a 370.
Is your bother running 317's? If not, that's an inexpensive way to drop the compression down to a boost friendly level.
Rick
Old Jan 17, 2010 | 01:12 PM
zippy's Avatar
Boost depends on the spec's of the motor. Heads? Cam? Headers? etc. As for the compression, with good fuel it'll last a while. Race fuel will get old real quick though. If it's a 370 I assume it's compression is high from the cylinder head choice so as they've said just change the heads or at least take them off and open the chambers up a bit and you'll be fine. Get the compression down to 10.5:1 or so and you'll be fine.
Old Jan 17, 2010 | 02:43 PM
so if i drop it to 10.5:1 i will be able to run how much psi...??
Old Jan 17, 2010 | 04:27 PM
zippy's Avatar
At 10.5:1 you should be able to run 8psi without a problem. 10psi with carefull tuning and 93 octane minimum.
