how much nos 2 spray with 10psi
Originally Posted by 1SlowHoe
If you do a wet shot you should be able to get away with it. However, bigger injectors and an inline and/or a bigger intank pump would be a good investment.
Hmm, I just re-read his original post. If his fueling is 100% stock, you're right he shouldn't even be able to do what he's doing.
Have you been on a dyo with your AFR being monitored? I bet you're over 100% injector duty cycle already.
And how did you get in to 11's and run 10psi with a stock fuel system?
I run 9psi with an 255lph inline pump with a voltage booster and 42# Ford injectors and I'm about maxed out.
