how much nos 2 spray with 10psi
Old Apr 3, 2007 | 10:41 PM
MR.QUIK's Avatar
Default how much nos 2 spray with 10psi
just woundering what shot would b safe with 10psi whipple stock 6.0 running a window switch 4 it and its a wet kit tunded by nelson
Old Apr 3, 2007 | 11:01 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I'd start with a 35-50 shot and see how it feels. It's gonna feel like a bigger shot because of the cooling effect on the boosted air.
Old Apr 3, 2007 | 11:10 PM
MR.QUIK's Avatar
cool i was thinking a 50 do you think ill have fuel issuses cus thats all stock 2
Old Apr 3, 2007 | 11:20 PM
parish8's Avatar
single digit dreamer
yes. you will need more fuel. without the nitrous your fuel system is marginal.
Old Apr 4, 2007 | 01:03 AM
WJ MARK's Avatar
I'd go 35 shot first. I know atleast on a turbo car a 35 shot will actually make about 50 hp. The same probably goes for superchargers.
Old Apr 4, 2007 | 08:05 AM
1SlowHoe's Avatar
If you do a wet shot you should be able to get away with it. However, bigger injectors and an inline and/or a bigger intank pump would be a good investment.
Old Apr 4, 2007 | 03:29 PM
parish8's Avatar
i dont see how a stock pump will handle a 6.0 at 10psi and 50shot.
Old Apr 4, 2007 | 03:34 PM
vanillagorilla's Avatar
A stock pump won't handle a 4.8 at 10psi. Geez.
Old Apr 4, 2007 | 04:40 PM
1SlowHoe's Avatar
Hmm, I just re-read his original post. If his fueling is 100% stock, you're right he shouldn't even be able to do what he's doing.
Have you been on a dyo with your AFR being monitored? I bet you're over 100% injector duty cycle already.
And how did you get in to 11's and run 10psi with a stock fuel system?
I run 9psi with an 255lph inline pump with a voltage booster and 42# Ford injectors and I'm about maxed out.
Old Apr 4, 2007 | 04:45 PM
CHEVRACER83's Avatar
I Dont See The Stock Fuel Pump Supporting A 6.0 At 5 Psi... Let Alone 10... And Lets Not Get Started On Squeezin It.
