how much nos 2 spray with 10psi
Old Apr 4, 2007 | 05:25 PM
vanillagorilla's Avatar
I've found that almost 400rwhp is the limit on a stock fuel system.
Old Apr 4, 2007 | 06:02 PM
91_bowtie's Avatar
In my 5.3, I had the stock pump and 44# injectors @ 111% IDC, while running 10 psi. The IDC dropped to 86% on meth.
Old Apr 6, 2007 | 05:45 PM
MR.QUIK's Avatar
its all stock fuel but my charger has 2 injectors where the tb was but if i go with bigger injectors will i defeet the purpose if i dont install a fuelpump
Old Apr 6, 2007 | 05:50 PM
parish8's Avatar
single digit dreamer
you need a fuel pump for sure even if you dont spray it. many people get rid of those extra injectors and just run 8 larger injectors but that requires tuning. you could run a wet shot on top of what you have now without any tuning, just add a fuel pump.
are you running race fuel? at 10psi you most likely need it and then add a little nitrous and you need it for sure. a 35shot hit on my old 6.0/whipple prety good especialy right off the line.
Old Apr 6, 2007 | 05:54 PM
nightrunner's Avatar
Mr. Obvious
for 10psi on a 6.0 WITHOUT n2o you NEED a walbro 255lph fuel pump and 42 lb./hr. injectors and maybe a voltage booster for your fuel pump
with n2o you might need to step up to 60 lb./hr. injectors
you really should have some tuning software to monitor your injector duty cycle
when you do the fuel pump and bigger main injectors, you wont need the 2 additional injectors that came with the whipple, they are just band-aids for a stock fuel system
Old Apr 6, 2007 | 05:57 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Why race gas?
MR.QUIK's Avatar
ya i run srait race fuel im looking 4 my dyno sheets 2 c what it was doing at the time of the dyno was with no nos but then i better do a pump and injectors i just dont wana miss with it that much cus its running pretty good dont wana worsen it and its tuned by nelson
Old Apr 6, 2007 | 06:03 PM
MR.QUIK's Avatar
whats another word 2 look 4 on the dyno sheet i cant find the idc would it b air/fuel
Old Apr 6, 2007 | 06:41 PM
91_bowtie's Avatar
the IDC isn't going to be on your dyno sheet. you need to log it.
Old Apr 6, 2007 | 07:02 PM
parish8's Avatar
Originally Posted by 1SlowHoe
Why race gas?
he isn't going to get away with 10psi of hot air on pump gas. at least i didn't.
