How much difference does a smaller pulley make?
Old Mar 20, 2006 | 06:21 AM
Whippled 496's Avatar
Default How much difference does a smaller pulley make?
Yeah, i know...you guys warned me it would be addictive. I guess there is nothing i can do now but . So here is my next question(S). How much difference does 1psi make? How many psi would i need to jump to notice a decent performance gain over what i have now (i want to get into the 13's)? Lastly, how many psi can i get away with before have to intall some sort of injection or an IC? I live at sea level (give or take a hundred feet) and the winters are cold and dry and the summers are hot and moist.
Old Mar 20, 2006 | 07:36 AM
KySilverado's Avatar
+1 psi = 15-20 hp as a rule of thumb. Upping boost without tuning or at least the ability to monitor KR and AFR can lead to disaster. Proceed with caution.
Old Mar 20, 2006 | 08:32 AM
TurboGibbs's Avatar
I know with my Radix, stock 4.8, and stock tune I went from 7.5lbs boost to 11.5lbs and it was the single best mod I ever made! Holly ****! I can't even explain the difference it made. Well with that particualar set up I ran an 03 Cobra from a 50 roll and he got me by about 1 car length to 100. Then with the tune he would have been beat by 2. A tune is a must with boost increase if you want to survive it of course. I was just lucky because Magnacharger has really conservative tunes.
Old Mar 20, 2006 | 08:55 AM
Tuning is not an issue, i am about 10 minutes from the dyno and tuner. Has it been established yet that a DMax intercooler will work on these trucks and that it will provide sufficient cooling (i would imagine it can considering Dmax's run 25+ psi)? I know there was some "back and forth" about it because it was a taller core, but i figured since i have the HD truck already, it may be a pretty easy MOD. I figure it will bolt right in, just a matter of some plumbing, manifold inlet, and compressor outlet to make it work. Am i wrong? Anyone have any PICs of a stock DMax engine bay so i can take a look at the plumbing?
Old Mar 20, 2006 | 02:42 PM
GMC_DUDE's Avatar
I did not go quite as far, up to 9.5 - 10 psi, depending on which gauge I use . The power increase was amazing, about half again as much as the original install gave me. I didn't have to tune, because the PCM was able to adapt to the new conditions, but if you have a GOOD tuner, then I would recommend it. Unfortunately, I have now maxed out my injectors at 86% duty cycle, so I can't go any smaller. As they say "Git 'er done!", believe me, you won't regret it.
Old Mar 20, 2006 | 03:02 PM
Are you running an intercooler? The only thing im worried about is going to be the summer heat. Not sure how much of an impact its going to have.
Old Mar 20, 2006 | 05:48 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yes the RADIX guys are running a2w intercoolers. You really need to get a fat intercooler on there and some meth injection so you can really have some fun
Old Mar 20, 2006 | 05:59 PM
hemidup's Avatar
I went from 8lbs of boost to 10lbs. WOW! Pulled the motor shortley thereafter, for a total rebuild, so I can get 15lbs. I'm a boost junkie now.
Old Mar 22, 2006 | 03:12 AM
GMC_DUDE's Avatar
[gotta type this whole thing over cuz the stupid server crashed ]
Yeah, the radix has a built-in intercooler. If you don't have one, then I think you are probably at your limit at 5 psi. It really would be best to add an intercooler before any more boost. A few thoughts on intercoolers:
1: If you are going air-to-air, try to keep the pipe length and overall volume as low as reasonable. Otherwise the blower has to pressurize all that plumbing, which can cause lag.
2; If you have e-fans, be sure they are wired such that they are running any time you are in boost .
Denali08
Aug 9, 2015 04:34 PM
05GMC4.8
Aug 7, 2015 09:55 PM
blownss27
Jul 20, 2015 08:59 AM
smit2732
Jul 19, 2015 01:43 PM
bsn1989
Jul 16, 2015 08:20 AM
