How much boost can I run with 87 octane on an LS
#51
Late reply here.
But ive been running 87 in a 5.3 with a S475 turbo (5 PSI) in my daily.
You wont make much power with the setup at all on 87. I had to pull a lot of timing out and it just makes cool whistle noises now.
Its really not worth it. but if you do your own tuning you can get by with it on a daily just dont get in boost unless you have to.
I run COS5 (EFI LIVE 2002 Custom Operating System) so i use the "nitrous" timing retard for 87 octane to test it with. It feels like 100 rwhp loss on 87 with how its setup now.
Then you have to run majority of the fuel out to top off with 93 to be able to go back to the original tune.
#52
Only casually mentioned for whatever the reason the EcoBoosts run well on 87 ( yes they run well... not optimized but still run very hard) is direct injection. Fuel can't preignite when it's not present in the cylinder. That's something you can never match with port injection so if you want to run boost on an LS run premium gas. If you can't afford the gas like all my idiot friends that buy premium only vehicles and then run regular... leave the truck alone. You won't be able to afford the engine after you grenade it if you can't afford the gas in it. Yeah premium is expensive in Canada... I live here too and use it in everything.
#53
SSmikeSS
Oct 27, 2012 10:15 AM
