How much boost can I run with 87 octane on an LS
It takes very little power to cruise down the highway. For a small car anywhere 20-30hp, and trucks might be up to 60hp. You would not be in boost under these conditions. Of course, these values are on a relatively flat grade with light wind resistance. Going up a large grade or high headwind, or accelerating to pass can be a different story.
Although comparing a 6 speed all steel body to a 10 speed aluminum body might not be fair comparison as to how much the engine size and turbo effect performance. :-)
Is that air going somewhere? Yes
Is that air reducing the pumping losses in the engine? Yes
Does that lead to better econ? Yes
If it doesnt help, explain to me how a 2.7 ecoboost F150 4x4 gets better highway economy than my 1997 Buick Regal GS? One is a slippery sedan and one is a brick of a truck. But one spins a blower 24/7 and the other one gets to breathe easy on its waste energy. This isnt the only example I have in my pocket, so lets not harp on the differences of this 1 example. The truck in question also hauls tools around day in and out. Probably 500lbs of tools. So its a brick, its heavy, its 4wd and gets 27mpg on the highway. Its got turbos. Turbos help at cruise because they increase the VE of any internal combustion engine
According to the owners manual, it will run on 87, but they recommend 91+ for best performance. Which means they probably pull back timing and reduce boost when it detects enough knock to know your running low octane fuel. If all things are equal, direct injection is usually more knock tolerant because the it helps cool the combustion chamber mixture due to the latent heat evaporation effect.
Is the turbo spinning at cruise? Yes
- The 2.7L is still smaller than a 3.8L
- The compression ratio of 10.3 vs. 8.5 improves efficiency
- The supercharger on the 3.8L increases parasitic losses
- The 2.7L has improved ring technology and coatings to reduce internal friction
- The 2.7L has variable valve timing to increase efficiency at low speed
- The F150 has same coefficient in drag compared to a 23 year old Buick (albeit higher effective area), so not as much as a brick as one would think
- The F150 has 2 overdrives which are lower than a Regal GS
- The newer Ford has a must more sophisticated control systems than a 23 year old Buick
Sorry but the effect of the turbo on pumping losses is almost insignificant compared to other factors, and we will have to agree to disagree. Peace out.
