How much boost
Old May 9, 2013 | 01:54 PM
Alpinestar's Avatar
You should should be right around 500hp on 10lbs with that cam. If you're wanting to go ahead and run 12-15lbs I'd call yank and see if he would send you a converter for a 4l80e.
Old May 9, 2013 | 04:33 PM
Th045's Avatar
Im thinking 12 is probably going to be the magic number. Running 12 pounds what size injectors should I run and do I need to upgrade the fuel pump. Thanks for all the info guys
Old May 9, 2013 | 04:56 PM
Denali08's Avatar
Grap some 55 or 60Ibs injectors. You will need 255lph or better get Aeromotive 340. Stock pump will not be enough.
I am running one intank with racetronix pump harness.
Old May 10, 2013 | 08:55 AM
nonnieselman's Avatar
Yea i agree.. that 60E converter is goin to be junk once the trans breaks.
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
