how much boost
Old Apr 1, 2011 | 03:18 PM
blander66's Avatar
Default how much boost
what do you guys think is the max boost i can shove into my motor.
5.3 bored to a 5.7 L
8.5:1 CR Forged Pistons
Forged H-beam Rods
Balanced rotating assembly
Thunderacing Blower cam
Head and Main studs
60lb injectors
HP Tuners 2bar speed density tune
Whipple supercharger
Old Apr 1, 2011 | 04:05 PM
Atomic's Avatar
I have a gauge for that
You will probably max out the blower before the engine. What size whipple is it?
Old Apr 1, 2011 | 04:14 PM
Mangled03gmc's Avatar
Baltimore Whore
That seems like really low comp, daily driving would prob suck, unless you were always in boost. I have been through this debating on building a high boost set up on low comp..
Old Apr 1, 2011 | 04:16 PM
Atomic's Avatar
The most glaring answer is 15lbs since that will be your limit with the 2bar setup.
Old Apr 1, 2011 | 05:37 PM
Casey2323's Avatar
Default parts
Turn it max rpm and se ewhat boost it makes....... i dont think it will make 15
Old Apr 1, 2011 | 06:02 PM
blander66's Avatar
I believe it is a 2.2 L
Old Apr 1, 2011 | 08:21 PM
Atomic's Avatar
What size pulley?
3" pulley with the stock crank pulley should get you about 13lbs
Old Apr 2, 2011 | 01:10 AM
Blown06's Avatar
8 Second Truck Club
I made 23 psi on a short block very similar to yours. Like others have said, the blower will max before you can hurt the motor if tuning is good.
Old Apr 5, 2011 | 02:43 PM
blander66's Avatar
Good that is what i was hoping to hear, i did not want to get bit by the boost bug and over boost what the engine can handle
Old Apr 5, 2011 | 02:44 PM
Atomic's Avatar
Its a lot harder to do that with a blower than a turbo.
