How much belt slip in reality....
Old May 20, 2013 | 11:20 AM
03sierraslt's Avatar
I have a HD tensioner and set my belt length based on keeping my tensioner in the middle of its travel range. One advantage my setup has is that I have an adjustable idler that I can move and compensate for belt sizes and pulley changes within reason. My belt does not stretch a whole lot as its a 8 rib HD Belt.
Old May 20, 2013 | 11:35 PM
Blown06's Avatar
8 Second Truck Club
I like the green hd belts from gates
Old May 21, 2013 | 09:27 AM
Gadgetized's Avatar
I ended up stepping up to an 8 groove system and placing another tensioner near the snout to increase belt wrap on the supercharger pulley. It worked great and I got no belt slip. I will actually be selling the setup real soon. 2.6 supercharger pulley, 3 extra wide idlers, snout support, alt pulley, pwr steering pulley, 10% OD crank pulley, and the very low mile green gates belt. I just need to get some stuff together and post it up.
Old May 21, 2013 | 12:47 PM
_zebra's Avatar
makes children cry
does that rub when it gets hot?
Old May 21, 2013 | 01:04 PM
Gadgetized's Avatar
No, there is actually more clearance than what it looks like. When the engine turns centrifugal force actually pulls it farther away from the idler.
Old May 21, 2013 | 08:50 PM
Pocket's Avatar
Originally Posted by Bagman
Since we are on the subject of belt slip. When choosing a belt, how tight is too tight? or is there such a thing? with my belt the tensioner is all the way tight and does move a tad with rpm and belt stretch.
Old method
Find the longest distance between pulleys. You should not be able to twist the belt more than 45* by hand. If you cant twist it at all, its too tight. If you can twist it past 45*, its too loose
Old May 22, 2013 | 08:32 AM
BigKID's Avatar
I reached the limit of the 6-rib belt at 14psi with a 3.25" pulley on my KB 2.8L even with relocated and larger idlers for ~290* of belt wrap. Boost graph looked like a staircase. Boost would start at 14 and drop to 9 by the shift point then jump back to 14 then down to 9 for every gear. Went to a 3.5" 8-rib with overdrive crank and HD tensioner and now see a steady 15# across the rpm range. KB recommends an 8-rib setup on their units for anything over 15psi which I found to be accurate.
I think belt routing and hardware setup are large factors in how well a supercharger will work without slip.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Vortec350ss
Jan 12, 2016 10:36 PM
Gadgetized
Oct 22, 2015 09:06 AM
Chevy305
Sep 28, 2015 09:21 PM
murderedSS
Sep 27, 2015 10:16 PM
