whipple not boosting over 5 lbs
Old May 21, 2013 | 05:40 PM
86gen3's Avatar
Default whipple not boosting over 5 lbs
ik ive read some posts about the whipple sidemount not pushing more than 5 lbs but ive also read guys pushing 12lbs??????? I had a 4 inch pulley on there and went to a 3 3/8. still 5 lbs. any help is appreciated.
Old May 21, 2013 | 06:46 PM
03sierraslt's Avatar
Are you running the Whipple electronics and the Two Aux injectors still?
Old May 22, 2013 | 08:45 AM
nonnieselman's Avatar
more info and pictures please
Old May 22, 2013 | 05:31 PM
86gen3's Avatar
no whipple electronics and not running those injectors. single belt system.
Old May 22, 2013 | 05:47 PM
dmelvin's Avatar
Don't those have an internal bypass? Perhaps something to look into if they do.
Old May 22, 2013 | 05:51 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Old May 22, 2013 | 07:58 PM
8 Second Club
The bypass valve is opening, not fully, but some.
(Fully open at WOT on a 6.0 you see 2 pounds)
Needs to be adjusted.
I would also check for proper vac routing on the bypass valve. (There is also an electrical component to this but most folks bypass it. I actually used mine as a valet switch)
chopperloco
Jul 10, 2016 10:45 PM
fastjweb
Sep 1, 2015 11:21 AM
fastjweb
Aug 31, 2015 09:57 AM
fastjweb
Aug 15, 2015 10:47 AM
MS3Z
Jul 30, 2015 06:17 PM
