How important are ported heads for a FI setup?
Old Apr 17, 2007 | 11:15 PM
  #31
1SlowHoe's Avatar
Destroyer of Transmissions
Well I think......nevermind, I don't know what the hell you guys are talking about so I'm subscribing to read more.
Questions: I thought stock heads could only handle 14psi or so before lifting was a problem. If thats the case, saying "run stock heads and turn up the boost" isn't really an option if he can only turn it up to 14psi before hes risking a blown gasket. Yes/No?
He needs after market heads (thicker deck) and some ARP studs to keep them down. Yes/No?
Old Apr 17, 2007 | 11:24 PM
  #32
BigTex's Avatar
I don't know about the 14psi part. I'd imagine it has more to do with internal combustion pressures than pounds of boost. An inefficient truck with restrictions like stock exhaust might show 18psi but flow less air (and make less power) than a fully modded truck that only makes 12psi.
Old Apr 18, 2007 | 06:51 AM
  #33
TurboGibbs's Avatar
I kinda feel like it is the cam. Here is the basic same Cammotion cam that I had and I liked it. Only difference really is mine was ground on a 114lsa.
https://www.performancetrucks.net/fo...d.php?t=390021
Old Apr 18, 2007 | 06:53 AM
  #34
Wilde Racing's Avatar
How do I change this text
One thing to keep in mind is cylinder pressures,
Just because the stock heads lift somewere in the 13-16psi range on a stock engine, doesn't mean they will lift on a very low compression 408 at the same psi..
Thunder, what boost pressure are you at now?
Old Apr 18, 2007 | 08:45 AM
  #35
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Couple of things:
1) the heads won't have a negative impact on performance with FI -- just like NA, bigger heads let more air charge into the cylinders, which means more power -- it just isn't as 'mandatory' as with NA because of the FI. There may be something to the flashing idea, but it seems like the less likely option to me.
2) the cam looks like it has some serious overlap -- my 'rule of thumb' estimation for getting to zero overlap says that cam needs about a 118.5 lsa to be at 0*. I've also found that my dual pattern cam (virtually the same specs except 1* less LSA and reversed durations as the reverse split I now run) ran rougher (more KR, more stutter, tougher to tune, etc.). I know folks are now saying the pattern of the cam doesn't matter, but my experience was that reverse pattern cams wtfpwn dual patterns...
3) If you are already having the KR trouble (which, as you say, you shouldn't be at 8psi and 9.4:1) I wouldn't up the compression just yet.
Also, your DCR needs to reflect your boost as I said about, and I found a good online calc for that: http://www.rbracing-rsr.com/comprAdvHD.htm
BTW: That cam Mark posted up looks pretty good, but would be kinda small on 408 cubes. It's also cheap
Old Apr 18, 2007 | 05:28 PM
  #36
thunder550's Avatar
High on diesel fumes
Camshaft, Rod Length, Boost and Altitude Correction to Compression
Your engine summary is as follows: Bore 4.03 inches, stroke 4.00 inches, rod c-c length 6.125 inches, with a static compression ratio of 9.4 :1. Your camshaft specifications call for an inlet valve closing of 46.5 degrees ABDC (after bottom dead center).
Your chamber volume is 99.54 cc's. With this camshaft your dynamic, or effective stroke is 3.55 inches. Your dynamic compression ratio is 8.21 :1 corrected for cam timing, altitude, and rod length. Your dynamic cranking pressure, corrected for cam timing, rod length and altitude is 164.40 PSI. Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and 8 PSI is 12.68 :1.
Knowledge is power.
This is what your link gave me for my current setup.^^
Your engine summary is as follows: Bore 4.03 inches, stroke 4.00 inches, rod c-c length 6.125 inches, with a static compression ratio of 9.4 :1. Your camshaft specifications call for an inlet valve closing of 39.5 degrees ABDC (after bottom dead center).
Your chamber volume is 99.54 cc's. With this camshaft your dynamic, or effective stroke is 3.68 inches. Your dynamic compression ratio is 8.49 :1 corrected for cam timing, altitude, and rod length. Your dynamic cranking pressure, corrected for cam timing, rod length and altitude is 171.68 PSI. Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and 8 PSI is 13.11 :1.
Knowledge is power.
Here's with the Z06 cam.^^
Your engine summary is as follows: Bore 4.03 inches, stroke 4.00 inches, rod c-c length 6.125 inches, with a static compression ratio of 9.4 :1. Your camshaft specifications call for an inlet valve closing of 42.5 degrees ABDC (after bottom dead center).
Your chamber volume is 99.54 cc's. With this camshaft your dynamic, or effective stroke is 3.63 inches. Your dynamic compression ratio is 8.38 :1 corrected for cam timing, altitude, and rod length. Your dynamic cranking pressure, corrected for cam timing, rod length and altitude is 168.81 PSI. Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and 8 PSI is 12.94 :1.
Knowledge is power.
Here is with the cam Mark posted a link to ^^
Those are very different numbers than the DCR calculator that I have installed on my PC gives me. The difference is the numbers I put in. Do I use the seat timing or .05" timing duration numbers? The website tells me to use .05", but the software tells me to use advertised duration, which I understood to mean either seat or .006" numbers.
Old Apr 18, 2007 | 11:34 PM
  #37
Keith's Avatar
I have always heard that .006" number should be used.
Do you have the calculator that J-rod posted up on tech?
Old Apr 18, 2007 | 11:41 PM
  #38
thunder550's Avatar
I'm using the one that you can download from this site
http://www.empirenet.com/pkelley2/DynamicCR.html
Not sure if it's the same one.
  #39
Spoolin's Avatar
GFYS and STFU
I was following everything fine up to now...Great info thanks guys.
Silveradorst07
Dec 31, 2015 12:04 AM
JordanH
Aug 8, 2015 07:59 PM
Ketis
Jul 23, 2015 12:37 PM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
