How important are ported heads for a FI setup?
Old Apr 17, 2007 | 05:10 PM
BigTex's Avatar
I'd be tempted to stick with the LS6 heads. The chamber design with the double quench area should actually help prevent detonation and promote a better burn. You won't gain much power going from a 9.4 to 9.7 CR.
If those heads have a large chamber, you might look into another head that has the same general chamber design with less volume.
I agree with you on going with a little smaller cam, but I'd choose something in the mid-upper 220 duration range.
Old Apr 17, 2007 | 05:12 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
FWIW Im going with a 222/218 114 for my setup, which is what Richard recommended and and what Jones said to go with pretty much since I want TONS of low end power right off idle and work great with a 2600(stock 80e) converter.
Jones can cut your cam for 100 bucks to a much smaller one if you want to go that route, food for thought.
Old Apr 17, 2007 | 05:24 PM
thunder550's Avatar
High on diesel fumes
I'm not sure that the quench design makes much difference in my case. My pistons are not quench pistons. They have a huge dish (28cc) with a raised center bore. Here, you can see them in this pic...I may be wrong though...we're getting into things that are beyond my current knowledge.
Old Apr 17, 2007 | 05:27 PM
thunder550's Avatar
I'll keep that in mind, might be worth looking into.
Old Apr 17, 2007 | 05:38 PM
1slow01Z71's Avatar
Quench pads are the part of the head where the head presses down on the head gasket in turn pressing the gasket to the block and sealing the cylinders better. Quick and dirty explanation. The more/bigger quench pad(s) the better chance of not blowing a head gasket on high boost.
Old Apr 17, 2007 | 05:50 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Chris -- remember to adjust your DCR for your boost before you go to far down this road. I'm not 100% sure on this, but was told that calculating DCR on a boost engine is accomplished by multiplying the PR * NA DCR (where PR = (14.7 - boost / 14.7).
Old Apr 17, 2007 | 06:18 PM
parish8's Avatar
single digit dreamer
huh i can't explain it well but thats not what the quench pads are for.
Old Apr 17, 2007 | 06:22 PM
1slow01Z71's Avatar
Well maybe it was explained ot me wrong so please try, Im up for learning something new.
Old Apr 17, 2007 | 06:26 PM
BlownChevy's Avatar
blownerator
25 Year Member
Old Apr 17, 2007 | 06:28 PM
1slow01Z71's Avatar
So how does having that small area in teh combustion chamber that doesnt touch the gasket help with sealing the combustion chamber?
