How to hide sts, NOS,ls1 intake, meth,ect.
Old Nov 20, 2006 | 09:09 PM
TURBO8's Avatar
Default How to hide sts, NOS,ls1 intake, meth,ect.
I am going for the all stock look. I thoght I would post pic's of my engine bay to show how I tried to hide this stuff. I hid my meth resivor under the stock intake filter cover. I hid all of my meth lines to the intake, sts intercooler piping, and the IAT mode with the fan shroud. I hid the NOS plate,and lines under the engine covers, along with other sts stuff, and the ls1 intake. I also hid the boost-a-pump and two step under the fuse box cover. Here is the pic's.
Attached Thumbnails How to hide sts, NOS,ls1 intake, meth,ect.-afsanas-wedding-118.jpg   How to hide sts, NOS,ls1 intake, meth,ect.-afsanas-wedding-117.jpg
Old Nov 20, 2006 | 09:12 PM
BlackGMC's Avatar
Resident Retard
are you running fans, cause I can't see them
Old Nov 20, 2006 | 09:13 PM
TURBO8's Avatar
Yeah, ls1 fans.
Old Nov 20, 2006 | 09:17 PM
vanillagorilla's Avatar
I spy white exhaust manifolds! Hehehehe....
Nice work hiding the meth and nitrous. Where did you hide the bottle and solenoids?
Old Nov 20, 2006 | 09:47 PM
the intercooler piping will still catch a trained eye- paint all the intake piping black that will help out alot-
other wise looks great.
Old Nov 20, 2006 | 10:15 PM
TURBO8's Avatar
Thanks, the bottle is in the bed by the tailgate. THe noids are under the engine covers as well. The intercooler piping will be complettly under the fan shroud once I put the th400 in. (my 6 speed lost 2nd gear) I will remove the blowoff valve and tuck the piping under the the fan shroud more.
Old Nov 20, 2006 | 10:37 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Other than the blue rubber connections it pretty good. A can of flat balck Krylon would make those rubber parts blend in.
Old Nov 20, 2006 | 10:44 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Also tap you oil pan for you oil return line it is easy to pull the pan since you are 2wd.
Old Nov 20, 2006 | 10:45 PM
tarinitup's Avatar
9 Second Truck Club
Your truck looks very nice so why not just show off what you have? How will you hide the turbo noise from 20 psi?
Old Nov 20, 2006 | 10:48 PM
TURBO8's Avatar
Yeah, Im working on that!
