High intake temps, whats too high ?
Old 05-23-2012, 02:17 PM
  #21
nonnieselman's Avatar
Originally Posted by 03LQ9
Before I heat wrapped the pipes and turbo I was getting 4psi in 1st and 8 in 2nd gear. Now with the wrapped pipes it hits 6psi in first and goes right to 10 when it shifts into 2nd and holds there. The heat wrap really helped with the lag.
What size turbo?
Gears?
Mine would get 6psi no matter what but it was a 60mm.
Old 05-23-2012, 02:39 PM
  #22
03LQ9's Avatar
What size turbo?
Gears?
Stock sts 60mm turbo, 3.42 gears. I'm still dealing with wastegate issues. I'm using a super soft spring from a 4l60e trans. It opens early in first gear and apparently in 2nd the wastegate is not big enough ? With the stock sts 5.8lb spring it will go instantly to 10 psi in first gear at 1/2 throttle, I never tried going wot with that spring in, not sure what would happen ? Everything is hooked up correctly and the wastegate is fine.
Old 05-23-2012, 08:21 PM
  #23
Silverad0 SS's Avatar
the lq9 (stock) is only good for 12psi with a intercooler, no meth, 93 octane the pistons melt
Old 05-23-2012, 08:26 PM
  #24
i would look into a bigger turbo, your pretty much maxing the 60mm which is why she's running hot, what size wastegate?
Old 05-23-2012, 10:42 PM
  #25
A melted piston means it went lean from a fuel issue or bad tune. Not too much boost.
And i believe the other fella needs to go with a bigger turbo, or less boost.
That 60mm isnt near big enought for 10psi on a 6.0.
Old 05-23-2012, 10:46 PM
  #26
My buddy has a 5.3 and had a small 60mm on 10psi.
Went to a 76mm. On the same boost level it went from a 12.6 to a 12.2.
IATs were bout 60* cooler at the 1/4 mile trap.
Old 05-23-2012, 11:18 PM
  #27
03LQ9's Avatar
The wastegate is 38mm. I figured the 60mm turbo would be maxed out behind a 6.0l. What do you guys think a better choice for right now would be, go with a bigger turbo or get an intercooler ? From the sounds of it I could put on an intercooler, lower the boost to 8psi and it would make as much power as at 10 psi with now intercooler ?
Old 05-23-2012, 11:27 PM
  #28
Id go ahead and do a 70 or 76mm with an intercooler and it will roll out!
That lil 60 is good for 6psi. Much mure and your making heat. The 70mm on 10# and a IC would be just bout perfect.
The 76mm would let you have more power potential later on.
Old 05-23-2012, 11:30 PM
  #29
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Originally Posted by reese'91
Oh yea and i think on sts website their Turbo kits run around 110* without intercooler on like 6-7 psi
Yeah, no. It all depends on ambient.
When I ran my STS kit on 7psi, my IATs were 190*
... in Florida.
Old 05-24-2012, 12:22 AM
  #30
03LQ9's Avatar
What a/r for the 70 or 76mm turbo ?
Quick Reply: High intake temps, whats too high ?
