High boost #'s
Old Jul 19, 2011 | 10:37 AM
  #31
scooter k's Avatar
Originally Posted by 99bluefirebird
Your setup would work fine with a turbo, just set 12-14lbs max boost with that scr. The cam will bleed off a little but go with a large turbo so you have room to grow, probably an 88mm would be excellent. Then you can grow to 1100rwhp as your heart and checkbook desire. You will make enough off selling the tvs2300 you will have most of the kit paid for.
Here is my cam specs
224/230 .612/.612 116 LSA
What do you want for CR on a turbo? 9?
Old Jul 19, 2011 | 10:45 AM
  #32
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Boost is boost as far as the cylinder is concerned, doesn't matter what forced it through the intake ports. CR is going to lowering the overall timing you can run but that problem will be greatly reduced with the fact that you're running e85. The cam should probably be swapped though. Look at what stock48 is doing with a tiny 212/212 112lsa cam. With that said I'd just spray it.
Old Jul 19, 2011 | 02:44 PM
  #33
jiar577's Avatar
I think you need a Vette...
Old Jul 19, 2011 | 03:25 PM
  #34
scooter k's Avatar
Yeah probably but I can't put two car seats in that.
Old Jul 19, 2011 | 03:30 PM
  #35
Lucille's Avatar
Do both - keep the maggie add nitrous and lower your IATs.
Old Jul 19, 2011 | 04:58 PM
  #36
scooter k's Avatar
Is that spray bars?
Old Jul 19, 2011 | 05:23 PM
  #37
Lucille's Avatar
1 set for nitrous and 1 set for meth eventually.
Old Jul 19, 2011 | 05:35 PM
  #38
scooter k's Avatar
Who did that for you? How much boost are you going to run?
Old Jul 19, 2011 | 05:48 PM
  #39
Lucille's Avatar
Rick at Trick. Great guy to work with.
Eventually, I would like to see 15lbs and a 75 shot.
Old Jul 19, 2011 | 05:55 PM
  #40
scooter k's Avatar
Are you running the larger intercooler and spacer that he makes also?
