Help me ID a Supercharger
Old Jan 27, 2020 | 07:44 PM
arthursc2's Avatar
How cheap is it? I wouldn't pay over 1000 on it. It's old, bracket is kinda lame, and it needs work
Old Jan 27, 2020 | 08:20 PM
03sierraslt's Avatar
I would pass on it, you won’t be able to find any parts or pullies and I predict constant belt issues due to that bracket and design.
Old Jan 27, 2020 | 08:59 PM
arthursc2's Avatar
Pulley is also massssssive, so it's not moving **** for air IMO
Old Jan 28, 2020 | 01:49 PM
HawkZ28's Avatar
5 Year Member
Seller got back to me and said it's gear driven internally.
I was thinking the same price wise, as well as parts.
Old Jan 28, 2020 | 04:13 PM
arthursc2's Avatar
That only eliminates 1 manufacturer, sadly
Edit: Bearings will be easy to find, its too expensive to manufacture your own, so nearly every company uses standard bearings. That pulley looks custom to me, if its a standard shaft diameter (.625, .750, .875 etc) pulleys will be easy to make work. If the gears inside arent broken, no problems there
The one problem will be seals. 1 might be standard (like an SC Procharger) and 1 will most certainly be proprietary. You might solve that with some machine work, if you happen to know a guy, but be prepared for the snow ball, scope creep effect to come in and wreak havoc on your plans
Old Jan 28, 2020 | 04:29 PM
HawkZ28's Avatar
5 Year Member
Agreed. When all is said and done it's not a significant enough savings over a "1 piece at a time" Procharger or Vortech system.
Old Jan 28, 2020 | 05:30 PM
arthursc2's Avatar
I am a procharger fan boi
I dont know your budget, but my first P1 kit cost me 2700 and my second one has cost me ~3300. I bought both units used with brackets for right around 2k and the extra cost has come from things like water to air, 8 rib, powdercoat, rebuild and conversion to D1 etc
My last kit I found on Craigslist, so dont be afraid to look around
Old Jan 28, 2020 | 06:08 PM
terravast4's Avatar
hell yeah. bargain shop. I have picked up tons of great parts on this site alone. some used and some new.
Snacktime
Aug 4, 2009 06:07 PM
Colby 04
Jun 19, 2006 01:13 PM
ThunderZ28
Jul 20, 2004 09:32 AM
