HELP,lq4 twin turbo,
Old Jun 13, 2008 | 10:00 AM
chevellepowered's Avatar
Default HELP,lq4 twin turbo,
ok. swaped lq4-4l80e into 70 chevelle. runs and moves.. turbo's are on but not fully hooked up. kkr330 are the turbo's. they are water cooled and oil feed.. my problem is the lq4 has a factory oil cooler. can i just tap into that to supply oil to my turbo's,does it have enough psi?... were would i run water lines to and from the motor?. and dont kno wat fittings are what on the turbo.. which ones are oil and which ones are water?? any info would be a great help.. been ""searching
"" hear and there for 2 days now..
Old Jun 13, 2008 | 10:15 AM
nonnieselman's Avatar
Thats where my oil is supplied to my turbo.. Thats all i know.. not sure on the Water...
Old Jun 13, 2008 | 10:22 AM
t_thall's Avatar
there is a blocked fitting right above the oil filter that is easily drilled and tapped for a supply
Old Jun 13, 2008 | 10:34 AM
ZZebes's Avatar
Not on his truck since thats where his oil cooler goes
Old Jun 13, 2008 | 12:43 PM
kbracing96's Avatar
Just drill and tap the oil cooler feed block and get you oil from there. The return port would be preferred, but really doesn't make much difference.
As for you water lines, you can get a ford heater hose T that is 5/8 through and 3/8 on the T. Put those in you heater hoses and run them to the turbo fittings. It doesn't matter which way you hook them up, it will flow fine either way.
Old Jun 13, 2008 | 01:24 PM
SimpleManLance's Avatar
post some pics of the turbo. somone might be able to tell which is which.
Old Jun 13, 2008 | 04:55 PM
alright thanks i appreciate it a lot..
i am middle of building the oil feeds right now .and my intercooler just came in.. fedex..
thunder550
Oct 8, 2015 04:53 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
black6spdz
Jul 16, 2015 01:32 AM
NuckenFuts
Jul 9, 2015 08:45 AM
