Biggest injector with stock computer?
Old Jun 13, 2008 | 02:27 AM
stock48's Avatar
9 Second Truck Club
Default Biggest injector with stock computer?
I would like to know what is the biggest injector I can run with the stock PCM, WITHOUT AN INJECTOR DRIVER. Thank's J
Old Jun 13, 2008 | 04:49 AM
7845's Avatar
Banned
racetronix i believe has an injector thta behind 60psi they are 92lb injectors
Old Jun 13, 2008 | 05:24 AM
Wilde Racing's Avatar
How do I change this text
The biggest high-impedance injector you can find..
The bigest I've heard of are Racetronix 79 lb / hr injectors. You can find modified delphi's in the 80 -90 range, but I'd hate to try and tune those at idle....
Old Jun 13, 2008 | 10:53 AM
cablebandit's Avatar
9 Second Club
injector driver is no biggie. got my 96# injectors running at 35psi static fuel pressure...easy on the pumps and fuel system and plenty of injector for big power
Old Jun 13, 2008 | 04:08 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Amen.
My 96ers run waaaaay better than the Delphi 75s too.
Old Jun 13, 2008 | 04:19 PM
stock48's Avatar
9 Second Truck Club
So what's involved with the injector driver? Wiring, cost etc. Thank's J Also I will be running E85. I will start out with twin 255's, and if that's not enough I will swap a 255 for an A1000.
Old Jun 13, 2008 | 05:34 PM
I AM A MOTHERF*CKER
It's brutally simple Bro. Install took me 45 minutes and I hid everything. All you do with is snip the PCM to injector wires in the harness and solder one side to plug A into the driver box, and the other side into plug B. Then wire in amps and a ground, reset your injector tables to stock in the tune, dial in the correct size, and start it up.
As I recall, my injector driver was around $400 and in terms of drivability, it was the best $400 I spent on the truck (followed immediately by my Dr. X box for the 90mm).
Old Jun 13, 2008 | 05:49 PM
TrickTurbo's Avatar
Truck Sponsor
WE offer the FJO injector drivers. Got them instock ready to go.
Rick
Old Jun 14, 2008 | 12:38 AM
stock48's Avatar
9 Second Truck Club
Thanks guy's ! So will the Injector driver idle better with low imp 96lbers vs no driver and high impedance 78's?
Old Jun 14, 2008 | 11:49 AM
I AM A MOTHERF*CKER
Absolutely. Mine idles better than 60lb High-z's.
mzoomora
Jan 3, 2016 07:06 AM
MS3Z
Jul 30, 2015 06:17 PM
caliSSclone
Jul 23, 2015 11:04 PM
maxspeed05V
Jul 19, 2015 07:08 PM
gavin2005
Jul 16, 2015 12:09 AM
