which heads for boost
Old Dec 14, 2013 | 01:27 PM
stroker87's Avatar
Originally Posted by BigKID
That is a highly debated topic on here. It all depends on the goals and purpose of the truck. The general consensus is low boost/high cr for a daily or street vehicle that sees a good bit of out of boost driving or high boost/low cr for a max effort race application. Fueling plays a part in it as well when it comes to detonation resistance.
i have a 2004 rado with a stock 2001 LQ4 I be leave 9.4:1 CR
how must boost can be ran safely for a DD that sees the track now and then?
to the OP i hope you dont mine me asking.....
Old Dec 14, 2013 | 01:45 PM
cpolaris502's Avatar
Cool, kind of what I was thinking. That explains it perfectly for me. Thanks.
Old Dec 14, 2013 | 02:24 PM
6.0l RST's Avatar
I believe when I'm done it'll be a track night weekend carshow truck i beat on it on the street when I drive cause I'm in Maine cause there's a lot of good country roads in towns where it's 1 sheriff on duty at a time (let's be honest barely anyone thinks we have electricity) . But I'd like to find a happy medium of compression race street that's sorta y I'm doing an 80 and not an 88
Old Dec 15, 2013 | 10:39 AM
Gadgetized's Avatar
That is the same setup I have. Same pistons. I run the TSP 2.5 heads for a truck. I ended up opening up the combustion chamber a little, and that brought the compression down where I wanted it.
I will be doing another build soon and going with the 317s.
If you go with an L92 head and a big cam, you should check your valve clearance as those pistons were not designed for them.
Old Dec 15, 2013 | 09:14 PM
6.0l RST's Avatar
The cam it came with is low.6xx high .5xx I just did a lq9. L92 build with a .610 .617 cam no issues so with the dish l92 would be ok all day
Silveradorst07
Dec 31, 2015 12:04 AM
thunder550
Oct 8, 2015 04:53 PM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
