Having second thoughts
Old Nov 28, 2006 | 06:39 PM
Default Having second thoughts
Hope somebody has rectified this. What I've done like others is made my own transition block to feed the supercharger from the oil boss above the oil filter. But what I did was take the feed from the rear hole and drained the oil back into the front hole like an oil cooler would. I also have an external oil filter that feeds from the oil boss to the filter then to the supercharger. I called and asked paxton why they drain there oil into the pan as I don't want to chance a leak or drill fillings in my engine, they said that it was the least restrictive as the oil drain is gravity feed. The supercharger is too low to drain it into the valve cover. So 2 questions, will my lingenfelter hi-volume oil pump be enough to force the oil through the filter and into the supercharger and will the oil drain enough to go into the engine through the first hole? By the way I already have the oil system hooked up in a loop to first test it without the supercharger and the oil comes out pretty good from the drain hose. But am unsure if the same flow is there when its draining back into the engine instead of into a pail. I want to find out before I fire it up and run the supercharger out of oil.
Old Nov 29, 2006 | 01:13 PM
NXRICKY's Avatar
Former Vendor
Aren't both the holes Pressured oil.
Ricky
Old Nov 29, 2006 | 01:19 PM
camcojb's Avatar
I don't think it can go there. I think as above it's pressurized, but at the least it will be a drain restriction. Either into the pan, the block just above the pan, or the timing cover has also been used.
Jody
Old Nov 29, 2006 | 03:30 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Both passageways are pressurized, I would tap the return into the oil pan like they said to.
Old Nov 29, 2006 | 09:22 PM
Damn thats what I was afraid of any suggestion as to have the least impact of oil contamination? What to use to connect to the pan as it ain't comeing off. I thought both sides are pressurized but if so why do they have a cast block that loops the oil from one hole to the other and thats where they hook up the oil cooler lines to so how does that work of both are pressurized. I was told the rear hole is pressurized. Anyclairification is great.
Old Nov 30, 2006 | 09:04 AM
NXRICKY's Avatar
Former Vendor
Ok one port is from the oil pump. The other port goes back into the block to feed the engine. . So from the pump to the cooler out of one port, then back into the engine through the other port. All are pressurized flow.
the cast block is needed if you do not have an oil cooler with out it, you smoke the bearings and the engine.
The engine oil is returned to the pan from many place, around the bearings, pushrods etc.
to feed oil to a turbo or supercharger just tap into that block and run another line to the supercharger. Now to return the oil you need to drill a hole into the pan, thread install a fitting, and route your return line.
Ricky
Ricky
Old Nov 30, 2006 | 06:00 PM
Ok what about the external oil filter, is there sufficant enough pressure and flow to feed the supercharger or should I use it as a paper weight?
Old Dec 3, 2006 | 09:55 PM
Now don't tell me that i'm the only one thats added an external oil filter.
lukn4trbl355
Oct 21, 2015 11:19 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Lthompson
Oct 2, 2015 12:45 AM
carid
Oct 1, 2015 09:22 AM
Chevy305
Sep 28, 2015 09:21 PM
