Going for big boost on a forged 5.3
Old Sep 2, 2009 | 05:59 PM
06chevy5.3's Avatar
Default Going for big boost on a forged 5.3
My pistons should be here friday from wiseco, but i still need to get some head gaskets... The guy from race engineering where i bought the pistons from told me that my compression will be 10.4 to 1 with the pistons and the 61cc chamber in my stock heads with a stock gasket....
Dont know too much about compression ratios, but i do know too high with forced induction is not good....
I wana get around 15lbs of boost which is prolly max for the blower can i leave the compression ratio where it is at 10.4 to 1 or does anyone make a aftermarket thicker head gasket to drop the compression ratio?????
Also would you guys recommend using arp head bolts too?
Old Sep 2, 2009 | 06:01 PM
00ChevyScott's Avatar
Wearin' da big hat
A set of 317 heads would drop the compression a good amount.
Old Sep 2, 2009 | 06:03 PM
99ta's Avatar
For big boost I recommend ARP head studs!!!
Old Sep 2, 2009 | 06:05 PM
LsxCody's Avatar
Running that much boost I would get a set of 317s like mentioned above.
Old Sep 2, 2009 | 06:07 PM
LsxCody's Avatar
Or some ls6 heads
Old Sep 2, 2009 | 06:14 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I'd do the LS6 243's. Blowers like a bit more compression
Old Sep 2, 2009 | 06:55 PM
silver-mod-o's Avatar
Hunt&Fisherator
Look up Cometic and see what they can do for the thicker gaskets.
ARP head studs would be a must as well for reliabilitys sake.
As far as the heads are concerned, 317s will cause valve shrouding on that small of a bore. I'd personally do some 243s... Shoot for a compression ratio for a hair under 10:1
Could Wiseco put bigger valve reliefs or a dish in them maybe to drop some compression??
Old Sep 2, 2009 | 07:36 PM
old motorhead's Avatar
243's have less combustion chamber volume, but do they unshroud the valves any?
Old Sep 2, 2009 | 08:14 PM
Casey2323's Avatar
u plan to run a decent size cam?? 220? nothing was said/ask about camshaft....
Old Sep 2, 2009 | 08:58 PM
Hunt&Fisherator
They come stock on 5.3's so I'd say yes... The 317s aren't terrible, but they'd need to be massaged to fit properly as their made for a 4" bore ideally.
I run them on the 3.906 bore of my 347 but they've been worked over by WCCH specifically for this setup.
