Going for big boost on a forged 5.3
Old Sep 4, 2009 | 01:54 PM
  #21
1BADAZZSS's Avatar
Just tune for e85 and dont worry about it. You will have to run more boost to make same power on a lower compression motor as to running same boost level on higher compression.
Old Sep 4, 2009 | 04:41 PM
  #22
06chevy5.3's Avatar
Originally Posted by visHous00
241s would work well but I'd still go with either 317s or 243s
Originally Posted by Rick_Vor
2nd that. The 243's are so expensive because they flow so much better than the LS1 and LM7 heads. The 317's have the same ports and flow as the 243's but the big chamber turns most people off unless they are going boosted (as in your application). They are so cheap because there are a million sets around.
Cylinder Valve Lift in Inches
Head .200 .300 .350 .400 .450 .500 .550 .600
LS1 137 187 207 223 228 237 242 243
LS6 156 204 225 243 257 267 275 278
Go with the 317's.
Rick
Yah I changed my mind last night after psoting that and thinking about it for a little 317s have bigger ports and valves and will drop my compression down to a safe level for a everyday 93 tune....
Actualy you dont gain a whole lot by rasing compression 1 point 2.2% hp gain or somthin like that which is only 10hp even if i went from 9.5:1 to 15:1 which is impossible for a boost motor I only get like a 10% gain.... I think these guys are right tellin me to get 315s
Old Sep 4, 2009 | 04:43 PM
  #23
06chevy5.3's Avatar
On another note i got the pistons today and they are 20 over pistons figured they where gona be stock bore
Old Sep 4, 2009 | 04:45 PM
  #24
kbracing96's Avatar
Well that sucks, now your gonna have money in boring it too.
Old Sep 5, 2009 | 06:58 PM
  #25
zippy's Avatar
Compression is worth more than you would guess. Low compression makes for doggy response when not in boost. With only running 15psi I wouldn't recomend going any lower than 9.5:1. You're probably better with it at 12psi and 10.5:1. Look at the numbers LQ9's, L76's, L92's, and LS3's make with boost.
Old Sep 5, 2009 | 07:53 PM
  #26
LsxCody's Avatar
yeah youre right i would rather have around 10:1 with 12 psi than 8.8:1with lets say 18 or 20 psi
Old Sep 5, 2009 | 08:47 PM
  #27
06chevy5.3's Avatar
Yah but my boost is instant and the smaller pully i use to get to 15 or 17 psi the more air im getting in the engine which is more improtant than the pressure
I was just going by a chart i found that siad you get about 1-2% gain by raising compression 1 point then my pulley size is limited by the compression....
So it doesnt make sense to me to have high compression and get 20hp maybe from the compression increase and run a bigger pulley im still up in the air about which heads to gets everyones tellin me different things... I still might get the 317s and have them milled a lil or a tiny gasket
Old Sep 6, 2009 | 08:49 PM
  #28
slowswb's Avatar
look at this way bob you can make the same hp horsepower with that compression ratio with on now with the same pulley your at now. also 1BADAZZSS has a point you want to go bigger injectors already just tune it for e 85. i bet you and money will make more power with e 85 than 93.
Silveradorst07
Dec 31, 2015 12:04 AM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
black6spdz
Jul 16, 2015 01:32 AM
kdw8888
Jul 9, 2015 10:52 PM
