Getting the list together! Input needed
Old Sep 9, 2011 | 08:17 AM
sureshot's Avatar
Originally Posted by Rick_Vor
The nice thing about a Procharger is he could run a 3.90" or 4.0" pulley and drop his shift point to 5800 or 6000 and have more power under the curve from the additional boost at a lower RPM.
Rick
Exactly, I see 14#'s on mine with a 5800 shift point.
Old Sep 9, 2011 | 12:40 PM
kwk174's Avatar
Well that sounds good. I'll use the cam I have now and see how I like it if not I'm going to get a PatG cam
Old Sep 9, 2011 | 12:50 PM
kwk174's Avatar
Oh with my bottom end, I'm using stock rods and replacement 4.030 pistons due to my budget at the time so I'm nervous to run anything over 10*. Also the reason for the 80lb injectors is cause I'm wanting to run e85. Anybody running this?
Old Sep 9, 2011 | 03:01 PM
iregret's Avatar
Charlie Murphy!
Vortech Race Bypass Valve
Which Vortech Race Bypass Valve? I googled it and there are several different ones. I've got the p1 kit that I'll be installing shortly. I'll probably upgrade to a d1 in a few years.
Old Sep 9, 2011 | 03:27 PM
02'Z71ONDUBZ''s Avatar
What kind of pistons? 10* of timing isn't gonna get you anywhere close to your potential, with E85 you will be much safer and will be able to feed it the timing it wants.
Old Sep 9, 2011 | 03:45 PM
Rick_Vor's Avatar
Maxflow® Racing Bypass and Blow-off Valves | Vortech Superchargers
Bypassvalve, not the blow off (same unit, different spring rates).
Rick
Old Sep 9, 2011 | 03:54 PM
sureshot's Avatar
I think he meant 10#'s.
Old Sep 9, 2011 | 06:25 PM
Rick_Vor's Avatar
Ditto.
Rick
Old Sep 9, 2011 | 06:38 PM
iregret's Avatar
Charlie Murphy!
Rick
Okay that's the one I'll buy. But what's different about it vs the one that comes in the procharger kit? More accurate? Doesn't bleed off?
Old Sep 9, 2011 | 06:46 PM
iregret's Avatar
Charlie Murphy!
Here's a link to the eBay intercooler:
CXRacing Intercooler Front Mount 27x12x3 Civic B18 S13 | eBay
I think that's the one you speak of. It's got to be better than the procharger horizontal intercooler right?
