Getting the list together! Input needed
I know this has been discussed many times but I would like some help if needed.
I have just bought a procharger bracket for my new project. I do know that im going to go with a D1SC for my build. I am just getting a list together for all the items that i will need. Just to make sure i didnt miss anything. Im only wanting to run 6-10# due to my bottom end.
Bracket
D1SC
Fuel Pump(probably one that injectorconnection sells that flows 340 lph)
Intercooler and piping
80lb injectors
BOV(input on which needed)
Meth injection
Pulley?
New cam for the blower
TruTrac
Crank Pin kit.
Fuel Pressure, Boost Pressure, and Wideband gauge
Input would be great.
Thanks for the help with this.
Bracket
D1SC
80lb injectors
Meth injection
Pulley?
TruTrac
Crank Pin kit.
Intercooler and piping - eBay 27x12x3 and a 3" piping kit
80lb injectors - 40's are plenty w/Meth but 60's will go you room to grow to 15lbs w/meth. 80's are kind of an overkill but if you get a deal, go for it.BOV- Vortech Race Bypass Valve. Superchargers like bypass valves on the street and will help with your mileage.
Meth injection - Save up for an Alky kit. I wasted tons of time trying to get another couple brands to work like I wanted. My Alky works flawlessly and their cutomer support is #1.
Pulley - 4.0" for 10lbs on a 6.0l but your cam choice could drop the boost a little
New cam for the blower - what is the specs on your current cam? I'm always surprised how well some tight LSA cams work with Prochargers.
Crank Pin kit. - nice to do but not sure if it will be needed a 4.0" pulley. If you can borrow an install kit, go for it.
Fuel Pressure, Boost Pressure, and Wideband gauge - a must
Rick
I wouldn't be surprised if that cam rocked with a Procharger, espicially with that stall. Procharger usually recommends something with about a 10+ spread on the duration and 115+ LSA so you're not that far off with the +2. I know John (Mangled03GMC) rocks a low LSA cam with his D-1SC and he's loves it.
Rick
Rick
