General FI Questions
Old May 12, 2011 | 09:15 PM
LsF-150's Avatar
Default General FI Questions
2006 CC lm7, DD street truck, Ive decided I need boost. Really want a rear mount but I already have ARH longtubes that I want to continue to use. So Ive decided on a TVS. Couple things I want opinions on. Truck has 3.23's and I will not be changing that, blowers generally speaking prefer lower gears, what are everyone's thoughts and some results from members who have run a tvs with high gears? I also want 2 get the 2300 vs the 1900, mostly because my future plans are more motor but thats at least 1 summer away if not 2, will I be dissapointed in the 2300 on the 5.3 in the meantime? Everyone seems to recommend the 1900 for anything less than a 6.0l. No plans of cam and head work on the 5.3, only looking for things that will also work on the other motor when that happens...Probably a 408. The truck will not see any track time, just a fun street truck. Thanks!!
Old May 13, 2011 | 06:17 PM
LsF-150's Avatar
bump.
Old May 13, 2011 | 07:25 PM
Swerve7rpm2000's Avatar
Just get the 2300....If anyone says you will be disapointed im afraid u shouldnt listen to them...If you have the extra money get it and you will be set on your 408
Old May 13, 2011 | 08:01 PM
TIM Z's Avatar
11 sec. Truck Mod
You'll just have to run a dinner plate size pulley for now on the 5.3 but hell if ya got the cash buy the 2300!
Old May 14, 2011 | 04:55 AM
Spoolin's Avatar
GFYS and STFU
I was in your shoes about 6 years ago and went with STS kit. Liked it alot.
Those hears might be a little tall for the blower though.
Old May 14, 2011 | 10:15 AM
silver-mod-o's Avatar
Hunt&Fisherator
If the truck is light enough and you put a small stall conerter with it those gears should be an issue for a street truck. Some 3.73s would be ideal but the 3.23s won't be a disaster simply because if the tq that 2300 will make... I would consider a jackshaft model so you can underdrive it if need be on the 5.3 and overdrive it on the stroker
Old May 14, 2011 | 02:41 PM
LsF-150's Avatar
thanks for the help guys, any sponsors sell the tvs kits? think I've seen leftcoastjoe? mentioned quite a few times in older threads during my research. does that sound about right?
Old May 14, 2011 | 07:39 PM
kbracing96's Avatar
Leftcoast32 is no longer a sponsor or board member. Black Bear Performance is a Manacharger dealer,
Old May 14, 2011 | 08:29 PM
JFOLM's Avatar
I think a used 2300 jackshaft is in the classifieds right now. . .
Old May 14, 2011 | 09:04 PM
Atomic's Avatar
I have a gauge for that
My 1900 did fine on my 408, but if you have the cash get the 2300. What's your HP goal?
