I bought dash logic. You can have up to 8 "pages" of data from any obdII read parameter plus two analong inputs. Plus you can set warnings to chime you door and display on your display like if you get more than x knock or set conditions like if above x boost, and about y tps, if a/f ratio exceeds z, alarm. It's not in your line of sight line a gauge, but I like how I can set alarms and sort of automate itso I don't have to fixate on gauge, dashlogic will let me know.
Dash Command shows it as a supported PID but displays N/A or a blank when I try to display any form of the reading.
Have you actually been able to see a reading?
Before I turned off the FPCM, yes, I could see fuel pressure. The sensor signal goes into the FPCM so now I can't and use a VEI gauge to measure fuel pressure.
I can also see injector duty cycle as well. I don't have an oil pressure gauge but I can view that in the Aeroforce as well.
