Gauges for Supercharged trucks?
Old May 10, 2016 | 08:35 PM
mikeskiw's Avatar
Originally Posted by LongBlue
That's interesting. Aeroforce has a list of parameters on their site that it can read. I see fuel pressure and I can see injector duty cycle.
Dash Command shows it as a supported PID but displays N/A or a blank when I try to display any form of the reading.
Have you actually been able to see a reading?
Old May 11, 2016 | 12:23 AM
PSM's Avatar
PSM
I bought dash logic. You can have up to 8 "pages" of data from any obdII read parameter plus two analong inputs. Plus you can set warnings to chime you door and display on your display like if you get more than x knock or set conditions like if above x boost, and about y tps, if a/f ratio exceeds z, alarm. It's not in your line of sight line a gauge, but I like how I can set alarms and sort of automate itso I don't have to fixate on gauge, dashlogic will let me know.
Old May 11, 2016 | 06:55 PM
LongBlue's Avatar
Before I turned off the FPCM, yes, I could see fuel pressure. The sensor signal goes into the FPCM so now I can't and use a VEI gauge to measure fuel pressure.
I can also see injector duty cycle as well. I don't have an oil pressure gauge but I can view that in the Aeroforce as well.
01SilveradoJakee
37
Jun 8, 2016 11:21 PM
JASON 77
Apr 17, 2016 01:19 PM
juveteach
Apr 13, 2016 11:50 AM
Mean Green z28
Apr 11, 2016 06:56 PM
ironcityboom
Apr 9, 2016 08:20 PM
