Gauges for Supercharged trucks?
Old May 3, 2016 | 08:50 PM
mikeskiw's Avatar
Default Gauges for Supercharged trucks?
I am running dash command on my phone or ipad monitoring boost pressure, trans temp, oil temp, and cooling temp. The app seems to work great but I am really wishing it would capture fuel rail pressure and air fuel ratio. I may be able to add these but I would need to add a wideband, a pressure sensor and a reader to talk to the system.
What other gauges are you guys running?
Old May 3, 2016 | 09:29 PM
JASON 77's Avatar
In for snswers
Old May 4, 2016 | 08:15 AM
flatblack83's Avatar
Supercharged trucks usually run 3 major ones. Wideband afr, fuel pressure and boost.
Old May 4, 2016 | 08:33 AM
Atomic's Avatar
I have a gauge for that
If there isnt a sensor to measure it, you need to add one. At least a wideband sensor, but you will have to see if the controller can talk to your ipad. If you have a 2015+ then I think there is already a sensor for the high pressure rail.
Old May 4, 2016 | 10:11 AM
mikeskiw's Avatar
My truck is a 2007 Avalanche so it's probably not available
Old May 4, 2016 | 10:24 AM
Atomic's Avatar
You would need to install extra physical sensors then.
Old May 4, 2016 | 03:01 PM
LongBlue's Avatar
If your truck has CAN for sensor communication, you can get an Aeroforce Scan guage. It can read whatever sensor information that is on the CAN bus. I have a 2007 NNBS Silverado and you can read fuel pressure since there is a fuel pressure sensor on the feed line. Also can get dtcs, clear dtcs, look at fuel trims, etc...
Old May 10, 2016 | 02:06 AM
mikeskiw's Avatar
I have a $379 Innova Can Bus scanner and it doesn't see the fuel rail pressure... I would also love to see injector duty cycle.
Old May 10, 2016 | 07:36 AM
LongBlue's Avatar
I have a $379 Innova Can Bus scanner and it doesn't see the fuel rail pressure... I would also love to see injector duty cycel.
That's interesting. Aeroforce has a list of parameters on their site that it can read. I see fuel pressure and I can see injector duty cycle.
Old May 10, 2016 | 07:39 AM
madmann26's Avatar
I only have 2 gauges.
AFR and Fuel Pressure.
I had to use a sensor to see FP but it's not logged in HPT.
