Gathering info for turbo 6.2
Old Mar 15, 2016 | 08:47 PM
  #51
GMCtrk's Avatar
That's the same turbo I ran previously. Really good unit. Will make 800-850 rwhp.
Old Mar 15, 2016 | 09:12 PM
  #52
FetzerValve's Avatar
How did the S475 spool on your truck? I'm assuming you had it on the 6.0 in your sig...
Old Mar 15, 2016 | 09:48 PM
  #53
GMCtrk's Avatar
spool was excellent. Not instant by any means but very good.
Old Mar 15, 2016 | 11:23 PM
  #54
Nice. I'm looking forward to seeing what it will do on my 6.2. Do I absolutely need a BOV? I'm only going to be running 6 psi, if that matters.
Old Mar 15, 2016 | 11:28 PM
  #55
GMCtrk's Avatar
Yes you need a bov
And you think 6 psi is all you will run lol
Old Mar 15, 2016 | 11:31 PM
  #56
6 psi to start. Once I get more injector I'll turn it up. I also don't want to nuke the trans quite yet.
Old Mar 20, 2016 | 10:02 PM
  #57
Working on getting the intercooler piping. What diameter should I be running on the hot side and on the cold side? I've seen people recommending 4" on the cold side but is that overkill for just ~500 whp? I'm thinking of running 3" on both sides of the intercooler.
Old Mar 20, 2016 | 10:08 PM
  #58
GMCtrk's Avatar
3" is fine. 4" wouldnt hurt
Old Mar 20, 2016 | 11:00 PM
  #59
I'll just go 3" on the hot side and 4" on the cold side. As for oil supply; my cooler lines are leaking so I'm going to replace those. I'm thinking of tapping the block that mounts to the engine to get oil to the turbo. It seems as though this has been done many times but I can't seem to find a clear picture of where I need to drill/tap. Can anybody help me out here? What size drill and tap will I need?
Old Mar 21, 2016 | 10:17 PM
  #60
Ok, found a good pic of the location of the drain. I'm planning on using -10 for the return and was wondering if I need a -10 x 1/2 NPT or a -10 x 3/4 NPT for the fitting in the pan?
