fuel system upgrade
Old Oct 31, 2011 | 04:04 PM
  #21
chevyboy.520's Avatar
Originally Posted by black04
Could only find this in my documents. This is the pinout for my 04 but i know GM also had a plug with orange, black, grey and purple wire.
I re pinned this wiring harness, switch A and D and all is good now! so if the OP is considering doing a hot wire kit then, I'd go for it. If you have problems with blowing the pcmb 2 fuse under the hood, then you can just switch out the wires. So thanks for the wiring diagram. Hope this helps out any one
Old Nov 6, 2011 | 01:05 AM
  #22
Chevy_freak's Avatar
Just FYI, if your fuel pump was wired backwards it will spin backwards. Double check that it's pumping and not trying to suck from the line (yes, I wired the one in my yukon backwards and there was a lot of swearing before I realized why it wasn't building pressure).
Anyone know why they changed pump connectors?
Old Nov 8, 2011 | 08:30 PM
  #23
blue0453's Avatar
bringing this back. getting ready to order the aero pump, which one works best to replace the walbro. and where do you guys get your submersible fuel line?
Old Nov 8, 2011 | 08:45 PM
  #24
blue0453's Avatar
And another question. Im considering doing the return setup using the stock feed line and just adding a return line. Heres the idea. Is there quick connect fittings the connect to the factory fuel lines under the hood? Was thinking adding a fitting from the feed line that would run to the regulator, then from the regulator to the factory connect for the fuel rails. Then the return line to the tank. Is this a satisfactory setup? What size return line? Best place to tap into the bucket for return line? Thanks Nick.
Old Nov 8, 2011 | 08:55 PM
  #25
blue0453's Avatar
Ok I think these are what I need. Russell Performance 640860 - Russell Fuel Rail Fitting Adapters - Overview - SummitRacing.com Russell Performance 640940 - Russell Fuel Rail Fitting Adapters - Overview - SummitRacing.com Now I cant remember if there 5/16 or 3/8? And what is the best regulator to get?
  #26
I'm going to do this later this week on my truck(aeromotive 340 and the hotwire kit). Wish me luck
Old Nov 8, 2011 | 08:56 PM
  #27
gavin2005's Avatar
not sure what the part number was on the aero 340 i used but i think any of them will work.i think the only difference is which side the inlet is on.my pump come with connector and hose.if you go with return style then you can take regulator out your bucket and they will be plenty of room to run the walbro and aero 340.thats what i did
  #28
blue0453's Avatar
Good luck bro.. I will be doing it soon myself..
Old Nov 8, 2011 | 09:01 PM
  #29
gavin2005's Avatar
thats exactly how i did mine.yes russell and aeromotive makes the factory quick connects.i used -6 pushloc hose as a return with a bulkhead fitting in the top of the tank.that was easier than putting it in the top of the bucket but it might have been better there but it works good
Old Nov 8, 2011 | 09:06 PM
  #30
gavin2005's Avatar
you need the first one in 3/8 not 5/16 but thats it.the second one is right.can't remember what part number was on regulator i used but i believe it went up to 70psi and had a 1-1 boost rise
