Fuel System/Boost Help with P1-SC on LS1 in RST.
Old Jul 30, 2010 | 01:12 AM
  #21
Rick_Vor's Avatar
Originally Posted by Atomic
It made 411/386 with a 3.3" pulley (about 8.5lbs). Keep in mind I have a 14b rear, and 120lb 35" tires.
The 14 bolt is a HP killer for sure but it's damn near bullet-proof. That's some heavy wheels. What size/model tire and rim are you running?
Originally Posted by sureshot
Your fuel system should be fine with what you have mentioned. If you start upping the boost, you may have to go to a Bosch 044. 10psi is safe, especially with a good tune. Your truck should move!
I used some 42lb injectors and a Magnacharger Walbro 255 kit ($140+/-) and it easily handled my P-1SC @ 10lbs. The Maggie kit comes complete and ready to install in about an hour. I'm still running it (been over 3 years) with a snow Meth kit and still have room to up the boost down the road. A Bosch 044 is a little more involved $$$ and to install but will give you even more headroom than the Walbro
Rick
Old Jul 30, 2010 | 02:25 AM
  #22
Blown06's Avatar
8 Second Truck Club
5.13 gears? Are you serious?
Old Jul 30, 2010 | 02:30 AM
  #23
Atomic's Avatar
I have a gauge for that
Rick
For the cash I have in it, it better be damnit.
Tires are 325/65/18 nitto terra grapplers, load E 10ply tires. Wheels are 18x8.5 mb gunner 6.
If I had to do mine again I would go with a single 044 and upgraded wiring and not bother with the walbro, but my goals are a bit higher with a 408 and 6 lbs of boost.
Old Jul 30, 2010 | 07:57 AM
  #24
300zxls1's Avatar
11 Second Club
Everyone always gets so worked up about the gear ratio. I am running a 32" tall tire and have a T-56 swap so 6th gear is a .50 ratio. So 5.13's work out to be about the same rpm in 6th as a F-body camaro running stock tire size and 4.10's. So using a simple rpm calculator you input
5.13 gear ratio 32" tall tire(305/50/20) 75mph w/.50 6th trans ratio = 2,020RPM
For comparison F-body with stock tire size and T-56
4.10 ratio 26" tall tire 75mph .50 trans ratio = 1,987rpm @75mph in 6th
Old Jul 30, 2010 | 07:59 AM
  #25
300zxls1's Avatar
11 Second Club
Thanks for all the input I cant wait to get the ProCharger kit installed, should be a fun truck.
Old Jul 30, 2010 | 10:29 AM
  #26
300zxls1's Avatar
11 Second Club
Also turbogibbs runs the same trans and tire size in his truck along with the 5.13 gears.
nrmskate
Aug 11, 2015 02:44 PM
RONIN LSX
Aug 11, 2015 12:03 AM
05GMC4.8
Aug 7, 2015 09:55 PM
jrplz
Jul 9, 2015 12:07 AM
Black-Syde
Jul 6, 2015 02:12 PM
