fuel rails on stock intake?
Old Jul 29, 2009 | 07:32 PM
  #21
TURBHOE's Avatar
Originally Posted by FarmTruc
by spraying METH.
well i use METH too so i guess i'm good. how can we prove the flow of stock rails versus aftermarket rails?
Old Jul 29, 2009 | 09:51 PM
  #22
Rick_Vor's Avatar
Originally Posted by 4.8T
my Y is in the bucket. mine is a T because i couldn't get a Y at the time and i needed it done. it works fine. i will probably change it later but its good for now. here is what i did. i want it to work like stock and be an easy install. so i left the stock pump where its at didn't touch it. i left the bucket alone didn't touch it either. the filter that is in conected to the bucket is what also has the regulator. i cut the top off of the filter case. pulled the guts out and drilled a hole in the bottom. CAREFULL it will break. so i stuffed the pump inside the filter case put on the filter pad for the pump. then i Tee'd it into the stock pump feed. but since this one flows more i put the striaght part of the tee inline with the new pump and the feed line then the tee part goes to stock pump. then i clicked the filter bucket piece back onto the bucket and installed everything back together. then i drilled a hole in the top of the bucket and put a bulk head fitting with a hose going into bucket to help keep it full. then just attach return line to bulk head fitting.
Awesome! Thanks for the info.
Rick
Old Jul 29, 2009 | 11:32 PM
  #23
350SS's Avatar
Midnightrider...do you have the part number for the aeromotive rails you're using? I've been kicking the same idea around for a while. Glad to see it working out for someone with the truck intake
Old Dec 15, 2009 | 01:33 AM
  #24
Ford_Assassin's Avatar
Come Get Some!!
Originally Posted by Midnightrider
I have after market had to make my own brackets and i wouldnt trust the stock rail for anything with serious horsepower IMO. BTW i have over 3k in the fuel system these An fitting and what not are very pricey
Did you have any issues with the aftermarket fuel rail running into the alternator on the drivers side?
Thanks!!
Old Jan 24, 2010 | 07:02 PM
  #25
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
btt...
good stuff
OHsixLS3
Dec 27, 2016 09:30 AM
jdb11386
Dec 3, 2015 09:34 PM
Slammed96
Jul 27, 2015 07:22 AM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
