fuel rails on stock intake?
Old Jul 27, 2009 | 08:40 PM
05crew's Avatar
Default fuel rails on stock intake?
like it says. is anyone runing a stock intake with aftermarket fuel rails? need some this week
Old Jul 27, 2009 | 08:53 PM
TURBHOE's Avatar
just courious but why you need new ones? i'm using stock myself so no help there.
Old Jul 27, 2009 | 09:05 PM
05crew's Avatar
well im going to a return fuel set up and 2 intank pumps. and i was just looking at some fuel rails. but idk what works? i would like to buy a vic jr set up with fuel rails but can find who sell it like that at a good price.
Old Jul 27, 2009 | 09:27 PM
hellbents10's Avatar
LS1Tech Sponsor
Stock 03' rails will bolt on and save you some money, we use them a lot. Good for 1000hp! If not the Edelbrock rails that bolt onto the Edelbrock intake are less then $100 if I remember right.
Old Jul 27, 2009 | 09:29 PM
TURBHOE's Avatar
i have dual pumps and stock return rails on mine. i converted to return style myself. but if you want vic jr. take part number and type edebrock and part number into froogle.com usually works great for me.
Old Jul 28, 2009 | 05:28 AM
05crew's Avatar
what kind of FPR are you running and were did you put it?
Old Jul 28, 2009 | 01:20 PM
TURBHOE's Avatar
stock regulator. second pump just comes on with a pressure switch.
Old Jul 28, 2009 | 01:49 PM
05crew's Avatar
o. ok so i need a new FPR, everyone tells me this. i guess to push the 60s a little more..? thanks for all the info
Old Jul 28, 2009 | 02:38 PM
Rick_Vor's Avatar
Might be a dumb question but when you added the 2nd pump, do you have to put in a check valve on the 2nd line to prevent the primary pump from loosing pressure through the inactive hobbs-switch activated 2nd pump?
Rick
Old Jul 28, 2009 | 05:52 PM
05crew's Avatar
so i have a return fuel rail off an 03 avalanche and its not a flex fuel. it has a FRP on the rail and that will work the same as a mangafuel fpr? will it make my 60lbs inj push more than it would on my returnless fuel set up?
i might not be making no sense..sorry
