fuel rails on stock intake?
well im going to a return fuel set up and 2 intank pumps. and i was just looking at some fuel rails. but idk what works? i would like to buy a vic jr set up with fuel rails but can find who sell it like that at a good price.
Stock 03' rails will bolt on and save you some money, we use them a lot. Good for 1000hp! If not the Edelbrock rails that bolt onto the Edelbrock intake are less then $100 if I remember right.
i have dual pumps and stock return rails on mine. i converted to return style myself. but if you want vic jr. take part number and type edebrock and part number into froogle.com usually works great for me.
Might be a dumb question but when you added the 2nd pump, do you have to put in a check valve on the 2nd line to prevent the primary pump from loosing pressure through the inactive hobbs-switch activated 2nd pump?
Rick
Rick
so i have a return fuel rail off an 03 avalanche and its not a flex fuel. it has a FRP on the rail and that will work the same as a mangafuel fpr? will it make my 60lbs inj push more than it would on my returnless fuel set up?
i might not be making no sense..sorry
